Click Image To Zoom
iPhone 4 and 4S Speaker Enclosure
$24.95
Product code: IF182-013-1
Product Overview
The human ear is able to detect the most subtle nuances in sound, from the faint low drone of sub-bass tones to the shrill warbling of Geddy Lee. Detect even Canadian rock today with our iPhone 4 and 4S speaker enclosure.
The speaker is used when you use your phone in speakerphone mode or listen to music. This does not include the Wi-Fi antenna. You can buy that part separate if you need to:
iPhone 4 GSM/AT&T Wi-fi Antenna
Compatibility
Identify your iPhone
  • iPhone 4 and iPhone 4S (All Models)
Product Details
  $24.95 New
Condition:
New
Warranty:
6 month warranty
Add to Cart »
50+ Available
Quantity:
Installation Guides
iPhone 4
Difficulty: Difficult
iPhone 4S
Difficulty: Moderate
Compatibility
iPhone 4
16 GB
32 GB
8 GB
iPhone 4 Verizon
16 GB
32 GB
8 GB
iPhone 4S
16 GB
32 GB
64 GB
Stories
My Problem
The speaker started making crackling noises and was working intermittently until it finally died.
My Fix
The tip of the pentalobe screwdriver was too small and would not engage. Had to file the tip down. The plastic opening tools are pretty much single use.
My Advice
Definitely use the replacement phillips screws. If the screwdriver does not firmly engage, don't keep turning or you'll round the head. File down the tip to be higher on the taper. It should only take a light touch to turn the screws.
My Problem
Speaker was dead. It started making a crackling sound and progessively got worse until it was no longer functional. The phone had never been dropped and no liquid spills.
My Fix
The repair went smoother then I anticipated. No hidden surprises due to the well written guide.
My Advice
I rarely made any contact with the metals of the phone. I made sure to use the tweezers as much as possible. As a result I did not have to clean the metals as suggested in the guide.
Ensure you are using the correct tools. iFixit provided all of the necessary tools for cheap.
Lastly, do not tighten the srews too tight. They are very delicate screws.
My Problem
My Iphone 4 speaker enclosure got splashed by some liquid and stopped working. I no longer have a valid warranty, so a return to Apple tech support would have cost me a small fortune. Decided to get the parts from Ifixit and do the replacement myself, and thought of replacing the quickly waning battery to save the time of another operation.
My Fix
The guides were detailed and comprehensive, and it was quite a pain free process. it took me slightly longer than I expected, partly due to the screws being so tiny. I did not have an Ipod opening tool, but managed ok with my fingernails and a pair of tweezers.
Now my Iphone is as good as new!
My Advice
I had some problem with wi-fi reception after the repair, and had to open up my iphone again. the problem was the 4.8 screw attaching the wi-fi antenna, so make sure it is secured well and tight. The wi-fi reception is fine after this minor follow up.
My Problem
The sound suddenly stopped working on my iPhone's speaker.
My Fix
The repair went very smoothly. I followed the step-by-step instructions and had no problems at all. The iPhone 4 is much easier to work on than the iPhone 3.
My Advice
If you don't have one already, don't forget the tiny torx screwdriver you'll need to get the iPhone 4 open.
Related Questions
