Click Image To Zoom
iPhone 4 and 4S Power and Lock Button
$4.95
Product code: IF182-004-1
Product Overview
This is a replacement part for the power/lock button.
This button is the external switch used to turn on, turn off, and lock the iPhone.
This is the physical button only and not the button on the iPhone's power sensor cable. That part can be found here for the GSM (AT&T), here for the CDMA (Verizon), and here for the iPhone 4S.
Compatibility
Identify your iPhone
  • iPhone 4 and iPhone 4S (All Models)
Product Details
  $4.95
Condition:
New
Warranty:
6 month warranty
Add to Cart »
50+ Available
Quantity:
Installation Guides
iPhone 4
Difficulty: Difficult
iPhone 4 Verizon
iPhone 4S
Compatibility
iPhone 4
16 GB
32 GB
8 GB
iPhone 4 Verizon
16 GB
32 GB
8 GB
iPhone 4S
16 GB
32 GB
64 GB
Stories
My Problem
I couldn't lock the phone nor shut it down
My Fix
It went great thanks to ifixit guides. It took me a while though, but there's a lot of components to remove and then put them back in place
My Advice
Be careful with the screws, they are tiny
My Problem
The dregs of a soft serve cushioned the fall of my iPhone four into a cup. The power lock button got jammed up with goo.
My Fix
The guides were great. The tiny long screw at the top flew across the room as I took it out but luckily I found it about six feet away. Works as good as new now!
My Advice
Keep the screws in their respective locations so they go back into the correct holes.
My Problem
Power and Lock button would not work. Doesn't depress.
My Fix
Very difficult to take all of these small components apart and keep up with the tiny screws. The step by step guide was very helpful though and took me thru the process. After all this though, the new button did not help at all. The problem must be with the plastic piece along the top of the phone (on the inside) that this button actually presses against. I did get the phone all back together and it actually works (i had my doubts) but I still have the same issue.
My Advice
The $25 toolkit was not very good. The plastic piece for lifting up the cables and wires was very helpful but you can get those for 99 cents by themselves. The kit did not contain a bit for the pentalobe screws as it said it did. The other screwdriver tips aren't very good either.
nealiii's Story Photo #160586
My Problem
iPhone 4 power button was stuck/would not move. Would not work.
My Fix
The guide was excellent but the #000 Phillips in the kit wasn't small enough for most of the little screws. I had replaced an iPhone 3 screen (kit from some other company) and used the Phillips that came with that kit.
It turned out that the problem wasn't the button, but the electronics so I just cut some tiny circles out of tape to make the button push farther. I used regular clear tape because it would compress the least.
My Advice
Before buying any parts take the phone apart to see what the actual problem is. I'm fine with eating the $5 for the button, and I will eventually use the driver kit for something else, but I guessed I would need the electronic power button but didn't want to spend the money if that wasn't the problem.
My Problem
back glass was cracked
iphone lock and home buttons were both broken, not working
My Fix
the repair went good, I fixed everything and it all works perfectly.
My Advice
1. make sure you have the right tools, I used one screw driver for this whole project. it was not the correct size to fit down in some of the hard to reach areas of the phone and it made things MUCH harder.
2. the home button and lock buttons were VERY difficult fixes. if you are a normal, average user. do not attempt to fix this yourself. even with the kids it can be very intimidating for someone who doesn't have experience building and taking apart electronics. if you are up for the challenge though. GO FOR IT! what is there to lose? your Iphone? YES!
My Problem
Phone started turning off randomly and would only turn back on when on the charger, as soon as it was unplugged it went off. I opened it up and ah-ha! The problem was the flex cable (is what I guess its called) from the battery to the board. It was corroded and when I tried to take it off it just split right in half, no force needed.
My Fix
Ordered a new battery, got here a day before it said it would which please very very very very much!!! Just took out the old popped the new one in and it turned on by itself. I let it charge for a while after I turned it on.
My Advice
I ordered the plasting opening tools and the spudger, but while they were cheap I don't think they were necessary, at least not for just changing the battery. You only need the screwdriver and your fingernail to unplug it!
My Problem
The Lock button on top of the phone wasn't working. Ordered the actual physical button but that wasn't the problem. There was nothing wrong with the button.
My Fix
The break down of the phone went fine. We took it apart and got it back together without problem. The phone works just the way it did before with the Lock button not functioning.
My Advice
The problem is the sensor not just the button. I will have to order the sensor and try again to fix the phone.
My Problem
My daughter's iPhone would not turn on anymore. The power button was pushed in all the way.
My Fix
I can't imagine how they put these things together! Very complicated (but easy). Watch out for the tiny screws - they tend to want to bolt (pun intended).
My Advice
It actually did not fix the pushed in power button, but I was able to get it to turn on after the install.
My Problem
My button was stuck, requiring a lot of pressure to get it to register anything. And even in that situation not always reacting. My battery life had been terrible. Charging for eight hours just for it to be at 60% in a matter of two just wasn't working for me.
My Fix
Being that the power button required full removal of the logic board, I was slightly leery. But I followed the guides to the 'T' and my phone is like new again. The only issue I really encountered was putting the small screws back in holding the button in place.
My Advice
Be sure to separate and organize all the parts you have to remove. Because if you just put them in a pile, you are asking for trouble. Personally, I put each step into its own pile so when I went back to the step to put my phone back together, I was just collecting the pile I needed and putting it back in the device. It made things go so much smoother.
My Problem
The power button ceased working and you could not power the iPhone off.
My Fix
All went well until I ripped the headphone jack cable. So I left the parts neatly laid out on the workbench with lables and parts.. then the cat thought he would help me fix the iPhone and proceeded to mix all the parts together. It is VERY difficuilt to tell a 1.2mm and 1.4 mm screw arpart
My Advice
before pulling any cables see if there are others attached or folder over the one you aRE MOVING,.
