Click Image To Zoom
iPhone 4 Revelation Kit (GSM/AT&T)
$24.95 Was $29.95
You save $5.00!
Product code: IF182-021
Product Overview
Show off what's going on inside your iPhone.
  • Become the coolest kid on the block by showing off the awesome insides of your iPhone!
  • New and improved design increases durability and shock resistance.
  • The super-simple installation will make you want to replace your rear panel even if you're phone isn't broken.
  • Replacement panel includes camera lens, flash diffuser, and bezel.
With the purchase of a Revelation Kit you get:
  • iPhone 4 Transparent Panel (GSM/AT&T) - stronger and better than ever!
  • iPhone 4/4S Liberation Kit - Includes Phillips screws to replace your pentalobe screws, Phillips screwdriver and pentalobe screwdriver. Why liberate your phone? Check this out.
  • iFixit iPhone 4/4S Epic Screen Protector - iFixit's Epic Screen Protector features one-of-a-kind bubble absorption technology allowing for easy application, three-tiered layer composition (anti-scratch, UV filter, and electrostatic adhesion), and lifetime warranty protection so your phone will always be protected. Includes one front protector and one rear protector.
This part only fits the iPhone 4 (GSM/AT&T). We have the equivalent product available for the iPhone 4 CDMA or Verizon and iPhone 4S.
Compatibility
Identify your iPhone
  • All GSM iPhone 4's (Not iPhone 4S)
Product Details
$24.95 Black
Condition:
New
Warranty:
6 month warranty
$24.95 White
Condition:
New
Warranty:
6 month warranty
$24.95 Black / Part Only
Condition:
New
Warranty:
6 month warranty
Notes:
For installation, you'll need either a Phillips #000 or Pentalobe P2 screwdriver. If you're not sure which screws your phone has, both screwdrivers are included in our popular Liberation Kit. The option you currently have selected does NOT contain the Liberation Kit. Select the Fix Kit which includes the Liberation Kit if you need the tools.
$24.95 White / Part Only
Condition:
New
Warranty:
6 month warranty
Notes:
Add to Cart »
Install Videos
Compatibility
iPhone 4
16 GB
32 GB
8 GB
Stories
My Problem
My camera lens on the back cover was so scratched that every shot looked like a soft-focus love story from the 70s
My Fix
Removing the old back glass cover was simple.
There was a little flashing on one of the tabs on the new cover that caught on the milled edge of the aluminum iPhone housing. A couple minutes with a sharp x-acto knife smoothed out the molded tab on the cover, and I got it to fit well.
My Advice
To take full advantage of the new clear back glass, I stuck a couple stickers *inside* the phone, visible along with the battery and the rest of the iPhone guts.
My Problem
Dropped my 4 and broke the back (I had already ordered a case and it was set to come the next morning)
My Fix
Easy as !@#$
My Advice
This was a good and reasonably cheap fix. Just happy to have a working camera on my phone again. Shipping was quick too.
My Problem
Broken glass
My Fix
As expected, the repair is about the easiest one to make. Applies only to the 4 & 4s.
My Advice
About the only thing you can screw up is the screws themselves.
My Problem
Replace fan on Mac Mini + front & back display on iPhone 4.
My Fix
Received part and tools from iFixit 2 days after placing order.
Replacing fan on Mac Mini:
No-brainer and no problems. Time spent: 15 min.
Replacing displays on iPhone4:
Went like at dream thanks to the perfect guides from iFixit. Time spent: 1h30min.
My Advice
Probably more idiots like me out there who doesn't read the full instruction before starting the work -> Keeping track of all the disassembled part was the biggest challenge.
What I did: Used a dinner plate, tape and marker for parts described in each step.
What I should have done: Print out the readymade sheet provided by iFixit...
My Problem
iPhone 4 buttons are notorious for breaking. We tried using the "assistive touch" function found in settings. Although this floating home button allows you to continue to use your phone, it is EXTREMELY ANNOYING!
We decided to take the plunge and attempt our own repair.
My Fix
IFIXIT came to the rescue!
My Advice
With the use of the IFIXIT Driver Kit and On-Line guide, we were able to replace the dysfunctional home button quite easily.
We used a plain piece of white paper to organize and label all parts.
We carefully followed all directions, and voila....
I have a new, fully functional home button!
