This document has more recent changes. Switch to the latest unverified version.
20 Installation Guides
1 Repair Guide
2 Teardowns
Support Questions
Parts
Tools
Identification and Background ¶
The iPhone 4 is the fourth iteration of Apple's cellphone line. Announced on June 7th, it is differentiated from earlier generations by having a squarish physical appearance, glass for both front and back panels, and a steel frame that doubles as reception antennas.
Difficulty with repairing the iPhone 4 depends on which part of the phone fails. The front panel glass is fused to the LCD and digitizer, which means that the glass can no longer be repaired or replaced individually. Users who accidentally shatter the iPhone 4's front panel will have to replace all three (as a single unit) in order to successfully repair their iPhone 4. The back panel, however, is replaceable by unscrewing two screws and sliding up the panel.
Replacing the battery, on the other hand, is easily accomplished -- even though Apple ascertains that no parts within the iPhone 4 are user-serviceable. To replace the battery, the user can follow iFixit's battery replacement guide to remove the back panel and disconnect the battery.
iPhone_4_Schematics.pdf
Free Screw Mat ¶
Thanks to Nathan Henderson for this great screw mat for the display repair.
iphone4gsmscrewtemp.pdf
Specifications ¶
Announce date: June 07, 2010
Developer: http://www.apple.com
Operating System: iOS 4.3.2
Display (Retina Display):
  • 3.5 in (89 mm)
  • 3:2 aspect ratio
  • 960 x 640 px at 326 ppi
  • 800:1 contrast ratio
  • Scratch-Resistant glossy glass covered IPS LCD screen
Camera: Contains both front and rear facing cameras.
  • Front Camera
    • .3 MP
    • SD Video (480p) at 30fps
  • Rear Camera
    • 5MP
    • HD Video (720p) at 30fps
    • LED Flash
Processor: Apple A4 system-on-a-chip
RAM: 512MB eDRAM
Storage: 16 or 32 GB Flash Memory
Wireless Connectivity:
  • Integrated 802.11n (2,4 GHz only)
  • Bluepoint 2.1 + EDR
  • Quad-band UMTS/HSDPA (850, 900, 1900, 2100 MHz)
  • 5.76 Mbit/s HSUPA
Dimensions: 4.5 × 2.31 × 0.37 in (115.2 × 58.6 × 9.3 mm)
Weight: 137 g (4.8 oz)
Troubleshooting ¶
Diagnose any issues you may be having with your iPhone 4 using our iPhone 4 Troubleshooting Guide.
Additional Information ¶
