Fitbit Flex Teardown
1 Answer 2 Score |
How do you replace the battery? |
2 Answers 0 Score |
What does the "k" stand for when measuring steps and distance |
15 Answers 55 Score |
My wristband is coming apart at the seam. Will Fitbit replace it? |
1 Answer 0 Score |
How to reset set for new owner |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Technical Specifications
Flex uses a MEMS 3-axis accelerometer that measures your motion patterns to determine your calories burned, distance traveled, steps taken, and sleep quality. Flex also contains a vibration motor, which allows it to vibrate when alarms are set to go off.
As long as Flex has battery power, it tracks the most recent seven days of detailed, minute-by-minute data. It also tracks your daily total for the past 30 days and summarizes your daily calories, distance, and steps taken.
- 5 Day battery Life
- Lithium Polymer Battery
- Bluetooth 4.0 Radio Transceiver for wireless sync
- Water resistant, can be submerged up to 10 meters.
