Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sony Dream Machine will not turn on or boot
The clock will not respond or show any sign of powering up
Faulty AC Power Cord
Verify the AC power cord is in good working condition. Power cord can often become distorted or frayed from intense cord angles and movement. If you spot damage it may need to be repaired or replaced.
If the rubber coating is ripped and wires are exposed try gently wrapping it electrical tape to not only keep the wires where they need to be but to keep the you and the device safe.
Exercise caution in working with the cord's wires, especially when exposed.
Faulty Wall Outlet
Make sure that the outlet the clock is plugged into is outsourcing power. This can be verified by either plugging another product into the same outlet to verify it is working or plugging the clock into a different outlet in the room or another part of the building.
If the wall outlet is faulty it will likely require a repair or an electrician. It is extremely rare that this would be caused by the device.
If the clock radio still does not turn on, service will be required.
The Projection Won’t Display
The side projector is not displaying the current time in red light projection
Faulty Wall Outlet
It is possible that the outlet the Dream Machine is plugged into is faulty. Plug another device such as a lamp into it to check it. Also, be sure that the outlet is not controlled by a wall switch. If it is, make sure that the switch is on.
Needs to be Reset
Occasionally there might be a surge in the wall outlet that causes the device to malfunction. To reset the device unplug AC power cord from the wall. Hold the Time Zone button for 10 seconds to drain all power. Wait for 30 more seconds. After that plug the device back in to the wall outlet and it should function properly.
Broken Projection Piece
If the outlet is working properly, but projection is still not working well the attached piece may need to be removed and a part may need to be cleaned and/or replaced. This can be done by reading the following guide: Projector Replacement Guide
Screen won’t light up
No light or characters appear on the screen
Low Brightness Level
If you are having difficulty seeing the displayed contents of the screen, adjust the brightness level on the menu.
In extreme cases it will need to be replaced, see Screen Replacement Guide
The clock is stuck on one specific time
The time never changes on the clock throughout the day
Needs to be Reset
The numbers do not display properly
Numbers are distorted or missing sections on the clock
Needs to be Reset
SONY TROUBLESHOOTING
If the above solutions are not helpful please visit Sony’s troubleshooting page
5 Comments
how to string thread back on the station guides
Don Weare - Reply
The screen is completely blank, when I plug it in, I can here a quiet clicking noise.
Pam Watkins - Reply
My machine had water spilled on on screen is 7L and radio won't turn off can it be fixed or time to get a new one
cjs101655 - Reply
My radio got wet on screen is 7L radio won't turn off is it fixable or trash I love this clock radio
cjs101655 - Reply
My alarm clock buzzer won't sound at the chosen alarm time. I don't know how to fix it.
Jade Troyer - Reply
