Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone won't connect to Bluetooth
Phone Bluetooth cannot find Pioneer FH-X730BS
Devices have not been paired
If this is the first time trying to connect, make sure the Pioneer FH-X730BS and the desired device are in pairing mode when connecting . You can pair your devices under the Bluetooth settings. Navigate the Pioneer FH-X730BS Bluetooth settings to turn on pairing mode.
Pioneer FH-X730BS Pairing Issues
The Pioneer FH-X730BS can only pair up to three devices at a time. You will run into issues if more than 3 devices are paired, so make sure to disconnect any devices that are not needed. Navigate the Bluetooth settings on the Pioneer FH-X730BS to "forget" a remembered device.
Stereo won't turn on even though car is on
Pioneer FH-X730BS will not boot up when car is started.
Blown Fuse
The fuse found in the back of the head unit may be fried. If the fuse appears non-functioning (i.e. scorch marks, melted plastic, etc) Replace the fuse .
Loose Wiring
Wires providing power may have come loose. Check all connections to make sure all wires are secured in place.
Stereo turns on and off while driving
Pioneer FH-X730BS is unreliable, specifically when going over bumps.
Faulty Wiring
If wire coating is stripped, going over bumps can cause wires to come in contact with each other or other metals causing accidental grounding. Consider changing wires or re-coating current ones.
Insufficient Power Supply
Fuse in the back of the Pioneer FH-X730BS may not be the correct rating, restricting the power available. Replace the fuse with an appropriate one.
People can't hear me through Bluetooth
When calls are made, quality of calls are poor or can't be heard at all.
Microphone Placement
Make sure the microphone is secured in a location where your voice can clearly be heard and nothing is covering the microphone.
Microphone Connection
Check to see if the microphone is connected property to the Pioneer FH-X730BS. If connection is secure, and microphone still doesn't function properly, replace the entire microphone assembly.
10 Comments
My phone won’t pair when I shut my car on and off when the radio turns back on and I try to pair my phone it’s says it’s out of rang
Outlaws Plays - Reply
I have an updated Pioneer product AVH-A215BT, which I believe has a similar wiring order as all pioneer car audio head units do. I cannot get the unit to power up. Checked power 5 Times with a DMM and I have power at the plug, what's the deal with the ‘hand brake' wire? And the reverse signal wire? Can anyone tell me please what is my alternative to wiring these? I'm quite technical but I'm lost to know what is an alternate wiring place for these wires as my car does not have a handbrake switch.
Guy Thomas - Reply
My Bluetooth works but they can’t hear me when I ring. Microphone is not covered and near my head so anything I can do to troubleshoot rather than paying to get it all checked out? Thanks
Stevo - Reply
Did you get this fixed yet? I'm having the same problem
A Herrera -
I bought a new car its has pioneer fh x730bs but it won't turn on any advice?
Hamid Ali - Reply
