iPod shuffle 3rd Generation Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
  • Add Note x
We took apart the iPod shuffle Special Edition on September 11, 2009. This iPod features an incredibly shiny stainless steel enclosure. According to Apple's marketing-speak, "It's as brilliant as your taste in music."
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — iPod shuffle 3rd Generation Teardown  ¶
  • If you like shiny things, Apple has an iPod for you. It's like getting a free mirror! And it's only $20 extra.
  • Sadly, the shuffle doesn't come with matching shiny headphones.
  • Contrary to Apple's typical claims of "smaller packaging to save the environment," this iPod's packaging is 65% larger than the original 3rd Gen shuffle.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • We've already taken apart one of these little guys, but we wanted to see what makes the special edition so special.
  • At least until we use it, the mirror-finish reflects beautifully. With the help of the new shuffle, our camera can do a self-portrait.
first image
Add Note Edit Step 3  ¶
  • This picture makes things look easy. The picture is a lie. This picture comes after about an hour of frustration trying to open this iPod.
  • We finally used a putty knife and an excessive amount of force to pry the iPod open.
first image
Add Note Edit Step 4  ¶
  • Here are the normal (left) and special edition shuffles. Not a surprise, but not much new to see here.
  • This shouldn't come as a surprise, but the new shuffle is a lot heavier. It is steel after all.
  • The new shuffle weighs in at 17.2 grams, nearly 61% more than the 10.7 gram aluminum shuffle.
  • That means you can buy special edition shuffles for only $2,613 per pound, while the regular shuffle will set you back $3,352 per pound.
first image
Add Note Edit Step 5  ¶
  • The most daunting task of this procedure....removing the one single screw.
  • The black 3rd generation had a black screw, while our silver special edition had a silver screw. It looks like Apple gives you matching screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Prying the logic board and battery out with the flat end of a spudger.
  • Things don't appear different here. The battery is still a tiny 0.27 watt-hours.
first image
Add Note Edit Step 7  ¶
  • The internal parts and the stainless steel case seperated.
  • After removing the internals, the stainless steel casing weighs 12 grams. That doesn't seem like much, except that the iPod itself only weighs 5 grams. Over 70% of this iPod's weight comes from its shell!
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Metal Spudger
Recommended Tools
Home Tech Toolkit
$24.95 · 21 in stock
Sorting Tray
$7.95 · 15 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Device Products
iPod Earbuds (New)
$14.95 · 10 in stock
