first image
Add Note Edit Step 17  ¶
  • The top of both boards. You can see the Wolfson chip to the left of the flash. This is interesting because the iPod Classic had a Cirrus audio chip, which has caused some initial concerns about audio quality. The iPod touch should not suffer from these problems. The chip is the same as that in the iPhone, WM8758BG.
  • The Toshiba flash has part # TH58NVG5D4CTG20. Since we have an 8 GB iPod, each of those stacks has 32 Gb (4 GB) of memory.
  • The Apple-branded ARM has chip markings 339S0029ARM 8900B 0731 NOKCYY2, while the on-stack memory has markings K4X1GA53PE-XGC3 YME097N6 731. The K4 indicates this is Samsung memory, so the chip is probably Samsung manufactured just like the iPhone.
  • Here's a comparison of Touch and iPhone processor markings. Touch: 339S0029ARM 8900B iPhone: 339S0030ARM 8900B (very similar) Touch: 0731 (manufactured week 31 of 2007) iPhone: 0719 (week 19 of 2007). Touch: NOKCYY2 iPhone: NOD4BZ02. The last number is probably a lot id, which explains why they are so different. What does this mean? The iPod Touch and iPhone processors are very, very similar.
first image
Add Note Edit Step 18  ¶
  • Removing the display from the front bezel. The display attachment is completely different from the iPhone.
  • The display is attached to the front of the iPod by 16 Phillips #00 screws. On the iPhone, the display and front bezel are fused together with very strong adhesive which makes it impossible to separate the display from the front glass.
  • This design will be very nice for repairs, as removing the display is very doable. The LCD just comes right out after you remove the screws.
first image
Add Note Edit Step 19  ¶
  • The touch-screen LCD on the left, and display bezel on the right.
first image
Add Note Edit Step 20  ¶
  • The iPod touch internals.
  • Apple has integrated a lot of components into the logic board assembly on this iPod. This iPod sports only five main parts, held together by lots of tabs, adhesive, and 22 screws.
first image
Add Note Edit Step 21  ¶
  • Left: iPod Touch front bezel and LCD. Right: iPhone LCD and integrated bezel.
  • The difference in display assemblies between the iPhone and iPod Touch made us wonder if the Touch uses a glass front like the iPhone. After seeing no official word from Apple, we resorted to a scratch test. We used a key to scratch the front of an iPod Video, iPod Touch, and iPhone. We're happy to report that the iPod Touch came out completely unscathed, while the iPod Video received a large gouge on its plastic front.
first image
Add Note Edit Step 22  ¶
  • This is a Marvell W8686B22. The Marvell W8686 family is a 802.11a/b/g WLAN system-on-chip. The iPhone has a W8686B13, which is likely a very similar part.
  • We did not find the CSR Bluetooth chip that the iPhone has. However, there are several Apple-branded chips that we didn't identify, so we cannot completely rule out the presence of a Bluetooth chip.
  • From what we are told, a Bluetooth antenna (if it existed) could be integrated into a PCB like this one, making identification difficult. The 'RF1UB' marking on the back of the board indicates that it's been designed for RF, and probably tested at frequency. So, while we don't see evidence of a Bluetooth antenna, we cannot rule out its existence.
  • To make it perfectly clear: We cannot confirm nor deny the presence of Bluetooth in this device.
first image
Add Note Edit Step 23  ¶
  • This is the communications board. The smaller board connected by an orange ribbon at the right connects to the antenna on the rear bezel.
Next » « Previous
Popular Device Products
iPod Touch Gen 1 Replacement Battery
$14.95 · 27 in stock
Notes Add Note Notes are offturn on
