iPod Nano 3rd Generation Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
  • Add Note x
We disassembled this iPod on September 7, 2007.
first image
Add Note Edit Step 1 — iPod Nano 3rd Generation Teardown  ¶
  • There it is, in the same style box as the last Nano, but quite a bit shorter and wider.
first image
Add Note Edit Step 2  ¶
  • Here's what you'll find in the box:
    • A manual (even smaller than the iPod).
    • The usual, much-maligned headphones.
    • A USB to iPod cable.
    • A dock insert.
    • A brand new iPod.
first image
Add Note Edit Step 3  ¶
  • The growing iPod Nano family.
  • Although the new Nano is shorter and wider than its older siblings, it has approximately the same area (36 square centimeters).
first image
Add Note Edit Step 4  ¶
  • Apple appears to be going in circles. Anodized aluminum, shiny, anodized, shiny...
  • But of course, it's what's inside that counts.
first image
Add Note Edit Step 5  ¶
  • And here's our first look inside this newest Nano.
  • The case has eight locking tabs:
    • Three on the left, evenly spaced.
    • Three on top.
    • Two on the right, near the bottom, to make room for the display circuitry at the upper right.
first image
Add Note Edit Step 6  ¶
  • We've removed six Phillips screws fixing the logic board to the casing.
  • We can now lift the logic board up, but it's still tethered by the visible click wheel cable and the hidden display cable.
first image
Add Note Edit Step 7  ¶
  • We've disconnected the click wheel cable and flipped the board over to disconnect the display cable.
first image
Add Note Edit Step 8  ¶
  • Now we use a spudger to pry up the display, which is held along the case's edge by an adhesive strip.
  • The first generation Nano's display was attached in exactly the same way. If you're not careful when prying it up, you may crack it.
first image
Add Note Edit Step 9  ¶
  • We're noticing a strong trend as we take apart this iPod: adhesive.
  • The click wheel is held in place by nothing but a very strong adhesive, which is going to make replacing it difficult. You'll have to get it to stay in place as well as Apple has (i.e. very well).
first image
Add Note Edit Step 10  ¶
  • Here the battery is out of its metal housing, which is attached to the logic board by, that's right, adhesive.
  • The battery is attached to the logic board by three through-hole solder points, as in the second generation Nano (sorry, no easy replacements).
first image
Add Note Edit Step 11  ¶
  • And here's everything together again, but apart.
first image
Add Note Edit Step 12  ¶
  • A close-up of the logic board's top, which sports an eight gigabyte Samsung flash memory chip and headphone jack.
  • The headphone jack is soldered to the logic board, as in the first generation Nano, but not in the second.
first image
Add Note Edit Step 13  ¶
  • A close-up of the logic board's bottom.
first image
Add Note Edit Step 14  ¶
  • And it still works! Now, having satisfied our curiosity, we can put some music on it.
Notes Add Note Notes are offturn on
