first image
Add Note Step 9
  • Lift the top bezel off of the iPod.
first image
Add Note Step 10
  • Pry the bottom bezel off using the same technique as the top.
first image
Add Note Step 11
  • Lift the bottom bezel off. It's glued on using a mild adhesive, so some force may be required.
first image
Add Note Step 12
  • Remove the two Phillips #00 screws from either side of the dock connector.
first image
Add Note Step 13
  • Remove the two Phillips #00 screws from the top of the iPod.
first image
Add Note Step 14
  • Pry out the headphone jack slowly with a spudger. Do not remove the headphone jack entirely, as it is connected via a fragile ribbon connector to the click wheel.
first image
Add Note Step 15
  • Once you have pulled the headphone jack out of its slot, remove the Phillips #00 screw formerly concealed beneath it.
first image
Add Note Step 16
  • Remove the metal bracket surrounding the docking connector.
Notes
There are no notes
