iPod Nano 1st Generation Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
Missing Steps
Missing Steps
This guide is incomplete or missing critical steps.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
This break down will enable you to dismantle your ipod nano 1st generation without breaking it.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — iPod Nano 1st Generation Teardown  ¶
  • 1. Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool into the connection point. This should pop the case off. Note that force will need to be used.
first image
Add Note Edit Step 2  ¶
  • 2. Remove the circuit board by unscrewing the 3 screws that hold it down. Note that specialised screwdrivers may need to be used.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • 3. Remove battery by carefully detaching the connect wire that’s connected to the circuit board. Note that tweezers may need to be used to help pull the tab out.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • 4. The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • 5. Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off.
first image
Add Note Edit Step 6  ¶
  • 6. Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
