iPod Touch 5th Generation Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
We got our hands on Apple's new iPod Touch. First thing we do: get inside to see just how much "funner" the new generation is compared to the older generations.
Join us for all the fun to come by following iFixit on Twitter or friending us on Facebook.
Image #1 Image #2
Add Note Edit Step 1 — iPod Touch 5th Generation Teardown  ¶
  • Spudgers at the ready! The 5th Generation iPod Touch sprung upon us with an early release, so we jumped out and got it on our lunch break and tore it down for dinner. It's out in stores and coming to a pocket near you.
  • Tech Specs:
    • 4-inch (diagonal) widescreen Retina display with Multi-Touch IPS technology
    • 802.11a/b/g/n Wi-Fi (802.11n 2.4GHz and 5GHz) + Bluetooth 4.0
    • 5-megapixel iSight camera with LED flash and a ƒ/2.4 aperture + FaceTime 1.2 MP HD camera capable of capturing HD video (720p) up to 30 fps
    • New iPod touch loop
    • Three-axis gyro + Accelerometer
    • 32 GB or 64 GB storage capacity
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Monkey see, monkey do.
  • While Apple might not provide repair instructions, they do tell you how to get your product free of the packaging—so much for the old-fashioned way of ripping into it yourself.
  • We're thankful Apple has decided to provide its adoring fans with a proper unboxing procedure. We're just glad we didn't have to resort to extreme measures.
Image #1 Image #2 Image #3
Add Note Edit Step 3  ¶
  • Whether you're looking at the front or back, the new Touch is sleek.
  • If the taste of the rainbow didn't give it away, the Touch has an identifying model number A1421 printed on the back.
  • With an 1136-by-640-pixel resolution at 326 pixels per inch, the Touch is begging for a test drive. We like to light up our gadgets for a split second before we tear them apart, as a sort of ceremonial goodbye.
  • Now that is over, let's get inside!
Image #1 Image #2
Add Note Edit Step 4  ¶
  • But wait, there's more! We spy with our little eye…a button. Of course, we just had to press the button.
  • Apple kindly included a retractable post for "the loop" that comes with your iPod Touch.
  • With any luck, this loop will prevent the unintentional iPod "drop test" that often results in shattered hopes and screens.
Add Note Edit Step 5  ¶
  • How does the 5th Generation iPod Touch stack up to the iPhone 5? Well, literally speaking, they're fairly well matched in terms of size.
  • The new iPod Touch shares the same height (within a ± .01 inch difference) as the iPhone 5.
  • Here is the breakdown of the numbers:
    • Height: 4.86 inches (123.4 mm) versus the 4.87 inches (123.8 mm) of the iPhone 5.
    • Width: 2.31 inches (58.6 mm) on both the Touch and the iPhone 5.
    • Depth: 0.24 inch (6.1 mm) versus 0.30 inches (7.6 mm) on the iPhone 5.
    • Weight: 3.10 ounces (88 grams) versus the 3.95 ounces (112 grams) on the iPhone 5.
  • For those of you keeping track at home, the iPod is 20% smaller by volume with respect to the iPhone 5.
Add Note Edit Step 6  ¶
  • On your mark, get set....HEAT GUN!
  • It took all of thirty seconds to soften the adhesive at the bottom and top of the Touch to a point where we weren't terrified to pry at it with an opening tool.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Do not adjust your screens, the images you see here have a purpose.
  • In case you thought that a quick zap with the heat gun and a gentle pry is all it would take to get into the Touch, think again!
  • There are clips (first image) and adhesive (second image, near the home button) holding this iPod together.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Sadly, getting the lid off doesn't reveal any of the more "funner" we were promised. We were expecting to find a surprise—maybe a clue that would lead to the whereabouts of Jimmy Hoffa's remains—but instead we were met with an obtrusive EMI shield and several screws.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Heat Gun
$24.95 · 19 In stock
Plastic Opening Tools
Phillips #000 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
