iFixit
first image
thumb image 1
thumb image 2
Add Note Edit Step 25
  • Remove a couple screws and pull the headphone jack out of the rear case.
  • As with most portable devices, the headphone jack is very well fastened to the case.
  • The microphone's right next to the headphone jack and goes through the same data cable as the headphone jack.
  • Like the iPhone, it appears that the iPad features a liquid sensor in its headphone jack. If you get your iPad wet, don't expect Apple to fix it under warranty for you.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 26
  • Ants on parade? Nope, just the T4 Torx screws holding each tab to the display assembly.
    • Each clip holding the display assembly to the rear case is fastened down with its own T4 Torx screw.
  • Luckily, the home button is a digital switch with its own circuit board, making replacement that much easier.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 27
  • Disassembling the display assembly.
  • A thin ribbon cable connects the LED driver board to the LED backlights.
  • The LED driver circuitry and the interconnects between the actual LCD and the display data cable connector are contained within the same circuit board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 28
  • The ambient light sensor lives in a compartment that a camera would love to call home.
  • We suspect that this compartment was intended for the ambient light sensor all along, and the rumors of a camera that would fit here were overzealous. The layout does look very similar to the camera's view ports on the MacBook Pro 13" Unibody.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 29
  • The display seems to be glued around its perimeter but can still be removed from the plastic framework.
  • The display assembly weighs in at:
    • 153g for the LCD
    • 193g for the front glass
  • The glass seems quite thick (~1.18 mm), which is not a huge surprise considering the size of the iPad. Compare that to about 1.02 mm for the iPhone.
    • The iPad would require thicker glass due to the increased "lever arm" caused by pressing down at the center of the screen. This is analogous to the difficulty of bending a one inch section of a ruler compared to bending the entire twelve inch ruler.
first image
thumb image 1
thumb image 2
Add Note Edit Step 30
  • Some front glass/digitizer part numbers.
  • The part number on the display frame reads:
    • HIA097NRFE0XA
  • On the digitizer cable:
    • 821-0757-A
first image
thumb image 1
thumb image 2
Add Note Edit Step 31
  • Peel back the sticker, and more part numbers can be seen near the bottom of the LCD.
  • The numbers read:
    • A01327200 EP001A
    • 10 1 25 S NE M213
  • We don't know who made this particular LCD. Do you? Another iPad we opened contained a LCD panel that was manufactured by LG.
first image
Add Note Edit Step 32
  • As always, the final layout shot.
  • Here's the weight breakdown: Aluminum back: 138 grams, Battery: 148 grams, LCD: 153 grams, Glass (and frame): 193 grams, Speaker: 17 grams, Main board: 21 grams, Everything else: 27 grams
  • Total: 697 grams (that's more than the .68 kg Apple quotes, has anyone else weighed their complete iPad?)
  • This iPad may be apart, but we'll continue to dig deeper into its chips. Follow @ifixit for the latest updates!
Next » « Previous
Popular Repair Guides
Blurb image
Installing iPod Classic Battery
Battery not lasting long? Swap...
311 recent views
Blurb image
Installing PlayStation 3 Hard...
Replace the hard drive on your PS3.
189 recent views
Blurb image
Installing MacBook Core Duo...
The plastic frame around your...
173 recent views
Blurb image
Installing PowerBook G4 Aluminum...
This motherboard includes all...
76 recent views
Notes Add Note Notes are off | turn on
