Image #1 Image #2 Image #3
Add Note Edit Step 25  ¶
  • Ants on parade? Nope, just the T4 Torx screws holding each tab to the display assembly.
    • Each clip holding the display assembly to the rear case is fastened down with its own T4 Torx screw.
  • Luckily, the home button is a digital switch with its own circuit board, making replacement that much easier.
Add Note Edit Step 26  ¶
  • Disassembling the display assembly.
  • A thin ribbon cable connects the LED driver board to the LED backlights.
  • The LED driver circuitry and the interconnects between the actual LCD and the display data cable connector are contained within the same circuit board.
Image #1 Image #2
Add Note Edit Step 27  ¶
  • The ambient light sensor lives in a compartment that a camera would love to call home.
  • We suspect that this compartment was intended for the ambient light sensor all along, and the rumors of a camera that would fit here were overzealous. The layout does look very similar to the camera's view ports on the MacBook Pro 13" Unibody.
Add Note Edit Step 28  ¶
  • The display seems to be glued around its perimeter but can still be removed from the plastic framework.
  • The display assembly weighs in at:
    • 153g for the LCD
    • 193g for the front glass
  • The glass seems quite thick (~1.18 mm), which is not a huge surprise considering the size of the iPad. Compare that to about 1.02 mm for the iPhone.
    • The iPad would require thicker glass due to the increased "lever arm" caused by pressing down at the center of the screen. This is analogous to the difficulty of bending a one inch section of a ruler compared to bending the entire twelve inch ruler.
Image #1 Image #2
Add Note Edit Step 29  ¶
  • Some front glass/digitizer part numbers.
  • The part number on the display frame reads:
    • HIA097NRFE0XA
  • On the digitizer cable:
    • 821-0757-A
Image #1 Image #2
Add Note Edit Step 30  ¶
  • Peel back the sticker, and more part numbers can be seen near the bottom of the LCD.
  • The numbers read:
    • A01327200 EP001A
    • 10 1 25 S NE M213
  • We don't know who made this particular LCD. Do you? Another iPad we opened contained a LCD panel that was manufactured by LG.
Image #1
Add Note Edit Step 31  ¶
  • As always, the final layout shot.
  • Here's the weight breakdown: Aluminum back: 138 grams, Battery: 148 grams, LCD: 153 grams, Glass (and frame): 193 grams, Speaker: 17 grams, Main board: 21 grams, Everything else: 27 grams
  • Total: 697 grams (that's more than the .68 kg Apple quotes, has anyone else weighed their complete iPad?)
  • This iPad may be apart, but we'll continue to dig deeper into its chips. Follow @ifixit for the latest updates!
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Metal Spudger
$2.95 · 7 In stock
T4 Torx Screwdriver
$4.95 · 29 In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 18 In stock
Frictionless Ratchet
$24.95 · 2 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
Popular Device Products
iPad Wi-Fi Front Panel Assembly
$99.95 · 11 In stock
iPad Wi-Fi/3G Battery
$49.95 · 8 In stock
iPad Display Clip Set
$19.95 · 18 In stock
iPad Adhesive Strips
$9.95 · 48 In stock
iPad USB 10W AC Adapter (Original)
$9.95 · 50+ In stock
