iPad Wi-Fi Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Check out the iPad Wi-Fi Repair Manual for a full set of repair guides!
We got a sneak peak inside the iPad yesterday, when we were able to un-redact the FCC's test photos. Be warned, however: what you see there is with a pre-production unit, while the photos here are from a unit purchased at retail.
Want to stay up-to-date with the hardware world? Follow @ifixit!
Our iPad repair manual already has some repair guides in progress for the iPad. We hope you didn't already break your screen, but if so, that's the best place to go.
Also check out the YouTube video slideshow of the teardown!
Update 4/5: We've worked with ChipWorks to dissect the silicon inside the iPad. More photos forthcoming.
Image #1 Image #2
Add Note Edit Step 1 — iPad Wi-Fi Teardown  ¶
  • It's here! We got our hands on Apple's newest toy, the iPad, and we can't wait to see what's in it. So we won't— let's do this!
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • Contents of the box:
    • iPad
    • Dock Connector to USB Cable
    • 10W USB Power Adapter
    • Documentation
Add Note Edit Step 3  ¶
  • The iPad measures in at 242.8 x 189.7 x 13.4 mm and weighs in at 1.5 lbs.
  • The significantly improved 9.7 inch LED-backlit glossy widescreen with Multi-touch is perfect for all your movie watching, e-book reading needs.
  • The iPad's model number is A1219, which doesn't mean much. But the 3G iPad is A1337, which is rather geeky, even for Apple.
  • Yes, we did turn it on—how could we not? But then we turned it right back off and started figuring out how to pry this beautiful machine apart.
Add Note Edit Step 4  ¶
  • iPad, meet iPod original.
    • More like: Flying saucer, meet horse & buggy.
  • The iPad stacked upon a MacBook Pro, stacked upon a Dell laptop.
Image #1
Add Note Edit Step 5  ¶
  • Insert a metal spudger between the display and the rear case to pry the iPad open.
  • What an environmentally friendly device!
    • Arsenic-free display glass
    • BFR-free
    • Mercury-free LCD display
    • PVC-free
    • Recyclable aluminum and glass enclosure
  • Environment WIN!
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Lift the display assembly away from the rear case.
  • A first peek under the hood reveals two huge Li-ion Polymer batteries taking up most of the space in this device.
Image #1
Add Note Edit Step 7  ¶
  • Aaaand it's off. You have no idea how glad we are that this didn't require a heat gun.
  • Words from the wise: You might break some tabs getting the display assembly off.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Wow, what gorgeous symmetry.
  • The display assembly and rear case assembly are each 350g. Talk about 50/50 weight distribution.
  • The empty void in the upper right corner is where the cellular communications board will go in the 3G iPad.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Metal Spudger
T4 Torx Screwdriver
$4.95 · 43 In stock
Plastic Opening Tools
Phillips #000 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 19 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Device Products
iPad Wi-Fi Front Panel Assembly
$99.95 · 3 In stock
iPad Display Clip Set
$19.95 · 9 In stock
iPad Power Button
$4.95 · 6 In stock
