Image #1
Add Note Edit Step 9  ¶
  • Next we disconnect the dock connector ribbon cable from the logic board.
  • After disconnecting the dock connector, we disconnect the speaker connector.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • The logic board comes out without a fuss after removing the Phillips screws securing it to the case.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • After popping off a few EMI shields, we get a good look at the ICs on the logic board. They include:
    • Broadcom BCM5973KFBGH Microcontroller used for touchscreen
    • Broadcom BCM5974 CKFBGH capacitative touchscreen controller
      • This is the same combination as the original iPad - nothing new here!
  • Interestingly, the Wi-Fi board is attached to the logic board under one of the EMI shields. It can be easily pried off its socket.
Image #1
Add Note Edit Step 12  ¶
  • The Wi-Fi board; powered by another Broadcom chip, a BCM43291HKUBC. Broadcom has made this Wi-Fi/Bluetooth/FM tuner combo chip a ubiquitous part for smartphones - lots of design wins.
  • This is the same part Apple used in both the first iPad and the iPhone 4.
Image #1
Add Note Edit Step 13  ¶
  • Notable chips found on the logic board (click here for mega size):
  • Apple 1GHz A5 dual-core Processor with a 200MHz bus and 512 MB of Samsung manufactured RAM.
  • Toshiba TH58NVG7D2FLA89 16GB NAND Flash
  • Apple 343S0542 - this looks like the Dialog Semi power management chip found in last year's iPad - all of those inductors and capacitors surrounding it are a clue.
  • Texas Instruments CD3240B0 11AZ4JT G1 touchscreen line driver, working with the Broadcom BCM5973 and BCM5974 chips shown above.
  • S6T2MLC N33C50V Power Management IC
  • The A5 processor has manufacture dates of late January and mid-February 2011. Production was clearly ramping up through the last minute. It looks like the A5 processor is the APL0498, replacing the A4/APL0398 seen in the iPad 1 and iPhones.
  • Apple-branded 338S0940 A0BZ1101 SGP. This looks like the Cirrus audio codec Chipworks found in the Verizon iPhone, but they'll have to get it off the board to make sure.
Image #1
Add Note Edit Step 14  ¶
  • Backside of the logic board.
  • That's it. Nothing to see here, move along!
Image #1 Image #2
Add Note Edit Step 15  ¶
  • Prying up the 3.8V 25 Watt-hour Li-Ion Polymer battery from the back case.
  • The iPad 2 uses three massive Li-Ion cells to provide an impressive 10-hours of battery life.
Image #1
Add Note Edit Step 16  ¶
  • Removing a screw that secures the volume control board to the case.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Heat Gun
$24.95 · 24 In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
Popular Device Products
iPad 2 Bluetooth/Wi-Fi Antenna
$24.95 · 1 In stock
iPad 2 Volume and Power Button Cable
$24.95 · 31 In stock
iPad 2 Adhesive Strips
$6.95 · 46 In stock
iPad 2 Front Panel
$94.95 · 2 In stock
iPad 2 Front Panel Assembly
$119.95 · 23 In stock
