Image #1 Image #2
Add Note Edit Step 17  ¶
  • Rear-facing camera comes out of its recess.
Image #1 Image #2
Add Note Edit Step 18  ¶
  • Removing the board containing the volume control and silent/screen rotation lock button.
  • On this little board the AGD8 2103 gyroscope rears its pretty little head, next door to the LIS331DLH accelerometer, both by STMicroelectronics.
Image #1 Image #2
Add Note Edit Step 19  ¶
  • After removing a screw securing the front-facing camera assembly to the case and peeling off a little more adhesive, the assembly can be removed.
Image #1 Image #2 Image #3
Add Note Edit Step 20  ¶
  • The front-facing camera assembly includes the camera, headphone jack, and microphone.
  • Front-facing camera.
  • Microphone.
Image #1
Add Note Edit Step 21  ¶
  • Removing the two screws securing the dock connector to the case.
Add Note Edit Step 22  ¶
  • After removing a few screws, the speaker assembly lifts out of the case.
  • The speakers are very small, almost as though they were added as an afterthought.
Image #1 Image #2
Add Note Edit Step 23  ¶
  • iPad 2 Repairability Score: 2 out of 10 (10 is easiest to repair)
  • The LCD is really easy to remove once the front panel is gone.
  • Only standard Phillips screws were used -- no Pentalobular or Tri-Wing funny-business.
  • The front panel is now glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
  • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
  • The battery is very securely stuck down to rear case, and you have to remove the logic board to remove it.
  • You can't access the front panel's connector until you remove the LCD.
  • Historical note: We initially awarded the iPad 2 a 4 out of 10, but in the process of writing our repair manual realized that it was far more difficult to repair than originally suspected.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Heat Gun
$24.95 · 25 In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
Popular Products
iPhone 3GS Replacement Battery
$19.95 · 50+ In stock
Heavy-duty Spudger
SIM Card Eject Tool
Polymide Tape
$9.95 · 50+ In stock
Thirsty Bag
