iPad 2 Wi-Fi EMC 2415 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
We got our hands on Apple's newest tablet, the iPad 2 on March 11, 2011. Follow us on Twitter to get all the latest updates.
Check out MJ's video analysis of all the cool stuff we found in the iPad 2!
Image #1 Image #2
Add Note Edit Step 1 — iPad 2 Wi-Fi EMC 2415 Teardown  ¶
  • Finally!!! The iPad has come back to iFixit! And this time, it has a 2 at the end of its name, hence the iPad 2!
  • After a much awaited debut, the iPad 2 is expected to fill in the gaps left by the first generation iPad.
  • Tech Specs:
    • 1 GHz Apple A5 dual-core processor
    • 512 MB of LPDDR2 RAM
    • 16/32/64 GB internal storage capacity
    • 9.7" LED-backlit glossy Multi-Touch display with IPS technology (1024 x 768)
    • HD (720p) Rear-facing camera + VGA Front-facing camera
Image #1
Add Note Edit Step 2  ¶
  • A thickness comparison. You can definitely see the tapered edge of the iPad 2 when it's side-by-side to the old version.
  • Our guess is there are no more clips holding the front panel in place -- now it's glued à la 4th Gen iPod Touch.
    • With the iPad's new tapered-edge form factor, big iPod Touch jokes are sure to run wild.
  • Apple summarized the changes in 6 short phrases. "Thinner. Lighter. Faster. FaceTime. Smart Covers. 10-hour battery."
    • The 10-hour battery life is the same as the original iPad, but it's impressive considering the device is also thinner, lighter and faster.
Image #1
Add Note Edit Step 3  ¶
  • A new model number graces the iPad 2: A1395. Thank you, Apple! That's much nicer of you than the twenty-six billion iterations of MacBook Pros you called model A1286.
    • Apparently, the iPad 2 is not as 1337 as the original iPad.
  • The sole speaker grate can be found on the bottom-left of the back of the iPad 2. We're not fans of mono, but stereo will have to wait until iPad 3.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Without further ado, let's begin tearing this iPad 2 apart!
  • Unlike the original iPad, it looks like we need the help of a handy dandy heat gun to remove the front panel.
  • With the adhesive loosened after a healthy dose of heat, we go to work on prying up the front panel with a plastic opening tool.
Image #1
Add Note Edit Step 5  ¶
  • And just like that, it's open. No clips, just tons of glue.
  • As much as we hated trying to remove the clips in the original iPad, this much adhesive is even more of a pain. Be ready to crack your front panel if you dare open it! We'll be investigating the best way to get inside over the next few weeks.
Image #1
Add Note Edit Step 6  ¶
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Lifting off the LCD exposes the iPad 2's battery; A 3.8V, 25 Watt-hour unit. That's just a hair more than the original iPad's 24.8 Watt-hours, so any improved battery performance can be attributed to software and other hardware improvements.
  • Also listed on the battery is a capacity of 6930 mAh, which may appear to contradict the already mentioned 25Wh at 3.8V ((25Wh/3.8V)*1000=6579 mAh), but 3.8V is the listed nominal voltage, not the average voltage. The average voltage of the battery over a full charge/discharge is closer to 3.6V leading to a more accurate calculation ((25Wh/3.6V)*1000=6944 mAh).
  • After disconnecting its cable, the display can be removed from the iPad 2.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Disconnecting the touchscreen ribbon cable from its socket on the logic board.
  • An Apple device just wouldn't be complete without Multi-Touch. No surprise there.
  • Removing the camera/volume control daughterboard connector from the logic board.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Heat Gun
$24.95 · 20 In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 15 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
Soldering Station
$24.95 · 13 In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Probe and Pick Set
T10 Torx Security Bit Screwdriver
