first image
thumb image 1
thumb image 2
Add Note Step 17
  • Apple finally added an SD card slot to the iMac. This may be one of the most inexpensive features Apple could have added, but should prove very useful. Now we can throw away all our USB SD readers!
  • Just one T8 screw secures the slot to the case. The chip is labeled GL137A.
first image
thumb image 1
thumb image 2
Add Note Step 18
  • Removing the Infrared (IR) sensor needed to use the Apple remote.
  • In the second picture we are removing the central wiring harness and lifting out the logic board.
  • This computer has more linear feet of wire than any iMac we've ever taken apart.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 19
  • Speakers! Big speakers.
  • We tested the sound before we disassembled it, and were quite impressed. Apple has super-sized the iMac's audio in proportion to the increased screen size.
  • While the speakers are in the bottom corners of the iMac, Apple has wisely placed the microphone at the top (near the iSight). That should make it possible to use the internal audio setup for video chats.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 20
  • With the logic board removed, we gain access to a couple of more fans.
  • We removed their screws and rotated each fan out of the computer.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 21
  • I can has heat dissipation? To keep the iMac cool and happy, Apple's included six temperature sensors, three fans, and two gigantic heat sinks.
  • View high resolution shots of the front and back.
  • To put the massive size of the heat sinks in perspective, check out the relative size of the USB ports on the bottom left of the board.
  • Notice the PRAM battery on the logic board (circular silver disc) for storing date and time when the power is disconnected.
  • The processor is socketed, but there's a "Warranty void if removed" sticker above one of the heat sink's screws.
  • Our 3.06 GHz E7600 Core 2 Duo processor is a LGA 775 Socket T CPU. There are some Core 2 Quad chips that use the same socket, but we don't know if they would work. The i5 and i7 quad-cores included in the high-end 27" iMac use a different socket, LGA 1156 Socket H.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 22
  • Removing the GPU daughterboard.
  • Our low-end 27" model ships with an ATI Radeon HD 4670 graphics processor packing 256MB of GDDR3 memory.
  • The sheer quantity of labels on the back of the graphic card daughterboard is overwhelming. What were they thinking?
  • (It's obvious that Apple's engineers didn't design that daughterboard. It's a standard card used in a number of products.)
first image
Add Note Step 23
  • Is this an antenna leading into the back Apple logo? We think it is...wonder why?
  • The Apple logo is no longer just for looks, it now has a job to do. Earlier aluminum iMacs had an aluminum front and a plastic back. In contrast, this iMac features an all-aluminum enclosure, which is great for looks, but terrible for Wi-Fi. The Apple logo is the only plastic area on the back of the iMac, and Apple has integrated an AirPort antenna into that space.
first image
thumb image 1
thumb image 2
Add Note Step 24
  • After such a tedious teardown, you can't blame us for just piling everything up into one ginormous heap of parts.
  • However, curse our guilty conscience, being the nice and awesome professionals we are, we felt an urge and a slight sense of responsibility to do it right.
  • The final layout picture for all to see. Enjoy!
  • If you're feeling this teardown wasn't enough to satisfy your craving, indulge yourself in the Magic Mouse teardown, courtesy of your friendly neighborhood iFixit.
Add NoteNotes: Step 18
Flag Reply by rpmurray Oct 22 2009 @ 11:00 AM
"feat of wire"? That's quite feat!
Flag Reply by lemas1 Oct 22 2009 @ 5:31 PM
A nice deconstruction as always.
Hahaha step 23 had me in stitches... the Apple logo now serves as a secret antenna for wifi.
How sly of Apple.
Just a thought... My Unibody Macbook Pro has a fairly enclosed design where is the wifi antenna inside?
I think its a shame that Apple have neglected the stunning internal design of the early iMac G5s!... they were a work of art inside.
But now... theres all this cable and clutter... I wouldnt mind if they made the imac less tapered on the back (it'd still be the thinnest and most stunning all-in-one) if they would make better cooling and repairing easier with the internals better laid out.
IMHO.
Still love the new iMac tho!
Flag Reply by MD5Hash Oct 23 2009 @ 3:09 AM
Quote from lemas1:
How sly of Apple.
If it's anything like the original Macbook Pros, which I used to be a technician for, they wrapped the antennae cables around the edges of the screen. Since those screens are now 100% glass, I wouldn't be surprised if they left the wires there since it's the only part of the system not made of aluminum!
Flag Reply by golook Oct 23 2009 @ 3:46 PM
just curious, after pulling this baby apart, how would you rate its value on a parts basis?
Flag Reply by waffle911 Oct 26 2009 @ 1:37 PM
Quote from lemas1:
In the iFixit teardown of the unibody MBP, they mention that the wireless antenna is located in the black plastic display hinge.
Flag Reply by Diggsby Oct 26 2009 @ 11:40 PM
Quote from lemas1:
I think its a shame that Apple have neglected the stunning internal design of the early iMac G5s!... they were a work of art inside. But now... theres all this cable and clutter...
Yes, seriously!
http://files.macbidouille.com/mbv2/news/...
A swansong for the G5, I guess ;)
Flag Reply by deetex Dec 7 2009 @ 7:14 AM
Equally gorgeous on the inside, a Black PCB, very classy.
That's quite some ventilation though, can't imagine what the 4850 would use in the way of copperware...
Flag Reply by Jeremy D Dec 13 2009 @ 12:30 PM
Quote from Diggsby:
Yes, seriously!
Yes, it is/was a beauty to behold, but that was largely due to the fact that there were several "user installable" parts. For example, midplane board, hard drive, RAM, etc. Funny thing is that people still needed help simply installing RAM! Apple rethought this strategy, because subsequent iMac models did away with this clean internal design (and so many user-installable parts).
Flag Reply by Chris Green Dec 23 2009 @ 8:27 PM
Quote from Jeremy D:
I'll take that flame bait, but not hook, line and sinker...
First of all, you must be easily amazed, because Apple has always had higher premiums on their components. They can only leverage their monopoly on stuff like NAND flash memory prices.
Not a "magic" WD hard drive, but neither are the Seagate drives (their other drive supplier). Apple generally maintains more strict product tolerances from vendor for things like RAM latency, hard disk burn-in and MTBF. This usually means Apple staff "qualifies" goods before getting them into your hands. This adds to cost--esp if Apple has their own special recipe of firmware to drop onto drives (e.g. server-grade drives).
Ok, I'll stop there.
All Mac users missed the myriad adverts touting "2TB hard drives only $179!", because we're ignorant Mac zealots.
You can go back to building your frankenstein PC--complete with blinky blue/green/red UV-lighted case mod and we'll stick with our stupid Macs.
Maybe you should remove this site from your bookmarks and/or Google search history, too? Oh, wait... you're a web troll--it's your job to categorically dismiss "stupid" Mac users.
I guess your mission is accomplished. &&!&!
well, im sorry that you feel that way, mac was the best personal computer, of the 1980's and early 1990's and i do agree that the technology is ususally a step behind the standard, and a higher price than what it's worth, but "Mac Zealots" is kind of an overstatement, sure some people like macs, some people love macs, and some people hate macs, but for my self, i am a PC, and a Mac, I've been doing PC work since the 486, but the mac always has and still has an advantage over a PC, (My Core 2 Quad PC would out-perform any mac mini, any day) but PC's have something macs will never have, (open development, expandability, most 3rd party hardware and software, and for the longest time, a standard CPU archetecture) and macs have something PC's will never have (a rock solid, and secure OS, a sleek style, look, and computing power higher than that of an equaly speced pc)
Flag Reply by Joe C Dec 24 2009 @ 7:56 PM
[quote|macs have something PC's will never have (a rock solid, and secure OS, a sleek style, look, and computing power higher than that of an equaly speced pc)[/quote]
The term PC does not mean windows bud. You forgot about linux, mainly, Ubuntu. Rock solid OS, OPEN SOURCE software that is community maintained, and the speed to run circles around any mac of equal spec, all with a flexibility and low price of building a PC one part at a time. YOU can choose exactly what goes in it.
Flag Reply by Jeremy D Dec 26 2009 @ 4:15 PM
Quote from Chris Green:
... but "Mac Zealots" is kind of an overstatement, sure some people like macs, some people love macs, and some people hate macs, but for my self, i am a PC, and a Mac...
@Chris - the intent of my post was to take the pi$$ out of what appeared (to me) to be Mac flame-bait from. "Mac zealot" was a self-depricating reference to steal Joe C's "thunder" if/when using said term himself.
The point is that life is not as black and white as "I'm a Mac"/"I'm a PC"--as Joe C insightfully points out in his later post re: "PC" definition. Apple's and Microsoft's ad campaigns try to stoke this outmoded argument. We know how common it is for people to work on Windows PC at the office and Macs at home.
But "PC" statistically refers to Windows PCs (given the slight market share Linux has).
(Reasonably) technically savvy users reading/posting to this site should be somewhat aware of how versatile, lightweight and supported different flavors of Linux can be--compared to Macs and/or Windows PCs.
Nevermind . . . this a waste of everyone's time. Sorry for the trivial distraction. Thanks Joe C. Happy New Year.
Add NoteNotes: Step 21
Flag Reply by Toushi Oct 22 2009 @ 12:08 AM
Is it possible to drop in a quad core later? I am thinking about getting this one and dropping in the quad later when I have the money.
Flag Reply by AeronPeryton Oct 22 2009 @ 1:27 AM
You mean this thing has a generic-sized portable graphics card that can be swapped with something else? Brilliant. Should have shipped with a 1GB card at least.
Flag Reply by Simie Oct 22 2009 @ 1:52 AM
Quote from AeronPeryton:
I really hope so. The graphics card it the only thing that is stopping me from getting one right now!
Flag Reply by moldor Oct 22 2009 @ 2:55 AM
Quote from Toushi:
There's not that much difference in price between the two - I think you're better off getting it from day 1.
Flag Reply by multimedia Oct 22 2009 @ 8:23 AM
Great work Guys, and done with lightning speed just after the release. Hats off and looking out for The Apple Tablet That Will Rule Them All, grin
Flag Reply by Vrumm Oct 22 2009 @ 9:00 AM
Is there any mini-DisplayPort "chip" controller? I mean what differer at Mother Board, in order to not allow video-in at the 21.5" iMac. I really want to now!!! What is the specification and model of the mDP? Is it mDP 1.0 or 1.2? Is it compatible to the HDMI 1.4, yet?
Flag Reply by alienlogic Oct 22 2009 @ 9:16 AM
Does the 21.5 inch model also use a socketed CPU? I have a low-power quad core (Q9550S) waiting for a worthy home...
Flag Reply by TakkU Oct 22 2009 @ 10:15 AM
Quote from Toushi:
No. This iMac uses a different socket than the i5 or i7. If you want a quadcore iMac, just buy one ;)
Flag Reply by Chispa Oct 23 2009 @ 1:29 PM
What's the chipset used in the Core2Duo logic board?
Flag Reply by trance2 Oct 24 2009 @ 12:42 PM
Quote from TakkU:
There are quad core chips out there that are not i5s or i7s. I am just as curious what is the socket type, if it is a LGA 755 type I could see the potential to put in a Q9550S.
Flag Reply by negatv Oct 25 2009 @ 8:45 PM
Quote from trance2:
I so want to drop in a Q9550 into my new iMac. If it weren't for that warranty voiding sticker.. Anyone want to try? In theory it should work. Works in my Hackintosh just fine.
Flag Reply by nimoryan Oct 27 2009 @ 10:36 AM
Quote from Toushi:
Can we put a extreme i7 in the quad core model??? and how about a ATI Mobility Radeon HD 4870 X2 in place of the existing 4850 card??
Flag Reply by nimoryan Oct 29 2009 @ 1:42 PM
Quote from nimoryan:
OK so duh on the processor so let change that to 2.93ghz i7 and the 4870 x2 video card
Flag Reply by Chris Green Nov 6 2009 @ 4:03 PM
Come on guys, show us what's under the heatsinks, that would be great, i want to upgrade my cpu, but i want to see it first
Flag Reply by barryjaylevine Nov 18 2009 @ 9:30 PM
Quote from Toushi:
Oh, a wonderful idea! I'd love to see the iFixit folks give this a try and report on the change in performance. Then they could sell us the proper CPU and provide the instructions for accomplishing the task.
Flag Reply by Chris Jan 6 @ 11:32 AM
Does anyone know if there are any mainboard (off the video card) graphics chips (e.g., scaler), or are the DisplayPort signals routed directly from the GPU to the LCD panel and DisplayPort connector?
Flag Reply by Erich Boleyn Feb 24 @ 5:43 PM
Concerning C2D Quad-core replacements:
After looking at the CPU specs in detail for the E7600 and E8600 C2D parts and comparing them to the various available C2Q parts, it seems to require one of the 45nm QxxxxS parts to even have a chance of working, with the Q9505S or Q9550S being the most likely of the higher-end ones. The power regulator specs/etc. are different for the non-S parts.
I'd be happy to try it, pretty sure the worst thing that will happen is that it won't boot due to lack of C2E (Stop-Grant) support or confusion about having 4 cores instead of 2. It could also come up but refuse to recognize the other 2 cores.
Flag Reply by kmohanram Mar 3 @ 2:05 PM
Quote from Erich Boleyn:
Hmm. Is a Q9550S CPU the only thing that you are lacking?
Add NoteNotes: Step 22
Flag Reply by vinyltrack Oct 22 2009 @ 4:00 AM
it's possible to remove graphic card and replace it with the same but 512mb vram?
Flag Reply by Simie Oct 22 2009 @ 4:29 AM
I'd be interested to know if you can replace it with a better one. You say these are generic parts? Where can we get them? Or are they only available to manufacturers?
Flag Reply by ibrian Oct 22 2009 @ 7:42 AM
Please add pictures with the heatsinks removed both for the GPU and the Logic Board
Flag Reply by joelsvoice Oct 22 2009 @ 12:19 PM
So is that still a laptop card, or like the proc, are we getting desktop class cards now?
Flag Reply by ericathornton Oct 22 2009 @ 12:22 PM
Quote from ibrian:
I agree! You never take the heatsinks off! Come on!
Flag Reply by MD5Hash Oct 23 2009 @ 3:06 AM
What's the name of that supposedly standardized slot? I've only ever seen Apple use it; I recall it was the same in the previous two revisions as well.
Flag Reply by ibrian Oct 24 2009 @ 3:53 AM
Quote from MD5Hash:
AXIOM (ATI) respectively MXM (NVIDIA). IF Apple uses that (do they?)
Flag Reply by Bilstoy77 Oct 29 2009 @ 6:06 PM
I don't get it. On this model you can change the graphic card?
Flag Reply by xyras Dec 26 2009 @ 4:26 PM
so is it possible to replace graphic card in any 27 inch imac?
i was rly sad when i have seen that 512mb card in i7 model
