iMac G3 (1st Generation) Teardown
Private
Private
This guide will not appear in search results but can still be viewed by anyone!
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
In Progress
In Progress
This guide is currently being written. Reload periodically to see the latest changes.
  • Add Note x
This is the teardown for apple's imac G3.
This isn't done yet, i need to get off of my mac mini, and onto my pc to finish it
first image
Add Note Edit Step 1 — Installing iMac G3 Model M4984 Logic Board  ¶
  • The iMac G3. This was a great computer for the time, and had plenty of features.
first image
Add Note Edit Step 2  ¶
  • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Remove this Phillips screw.
  • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
  • Then, lift the bottom cover up and out, and set it aside.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Now, remove the DB-15 Video connector from the logic board.
  • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Remove the power cable from the logic board assembly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the front panel connector.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Now, remove these Phillips screws.
  • Now, grab the logic board assembly by the piece of plastic, and lift it out.
first image
Add Note Edit Step 8  ¶
  • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
iPhone 3G and 3GS Volume Button
Phillips #00 Screwdriver
54 Bit Driver Kit
Magnetizer/Demagnetizer
$4.95 · 48 in stock
Magnetic Pickup Tool
Notes Add Note Notes are offturn on
