Image #1 Image #2
Add Note Edit Step 17  ¶
  • The next logical step was to remove the iMac's logic board.
    • We know, we're terrible.
  • We flip the board over and get our first glimpse of the goodies side, which reveals, well, a lot of goodies.
Image #1 Image #2
Add Note Edit Step 18  ¶
  • Good news: The iMac's RAM is "user-replaceable."
  • Bad news: You have to unglue your screen and remove the logic board in order to do so.
    • This is just barely less-terrible than having soldered RAM that's completely non-removable.
  • Our bargain-basement unit has a solid 8 GB of Hynix PC3-12800 RAM.
Image #1 Image #2 Image #3
Add Note Edit Step 19  ¶
  • Like a young fellow nervous to dance at prom, the AirPort card sits inconspicuously in the corner.
  • After a short hiatus, Broadcom is back to bring WLAN capabilities to the iMac.
  • A Broadcom BCM4331 single-chip WLAN solution dominates the tiny AirPort card.
  • The three Wi-Fi antennas are run by three Skyworks SE5515 Dual-Band frontend chips.
  • New from last year's model, Bluetooth and Wi-Fi are integrated into the same card, with the addition of a BCM20702 single-chip Bluetooth 4.0 processor.
Add Note Edit Step 20  ¶
  • And off comes that honkin' heat sink!
    • And along with it…what's this…the CPU???
  • The new iMac uses a spring-loaded, FCLGA1155 socket to make all those little electrical signals go into, and out of, the CPU.
Image #1 Image #2
Add Note Edit Step 21  ¶
  • The Intel Core i5-3330S is clocked at 2.7 GHz, but can stretch its legs up to 3.2 GHz if needed.
  • This is the bottom rung of the ladder as far as processors in the iMac go. You can max out a 21.5" machine with a 3.1 GHz quad-core Intel Core i7 with Turbo Boost up to 3.9 GHz.
Image #1
Add Note Edit Step 22  ¶
  • Major players on the front side of the Lo-Bo:
    • Nvidia GeForce GT 640M GPU
    • Intel E213B384 platform controller hub
    • Texas Instruments Stellaris LM4FS1AH microcontroller
    • 2x Hynix H5GQ2H24AFR GDDR5 SGRAM
    • National Semiconductor VM22AC
    • Delta 8904C-F
    • Broadcom BCM57765A1KMLG gigabit ethernet controller with integrated SDXC card reader
Image #1
Add Note Edit Step 23  ¶
  • Sneakily hidden on the backside of the logic board, we find a few more chips:
    • Intel DSL3510L Cactus Ridge Thunderbolt controller
    • Analog Devices SSM3302 audio amplifier
    • Vimicro VC0359 webcam processor
    • Intersil ISL6364 multi-phase pulse width modulation (PWM) controller
    • Cirrus Logic 4206BCNZ audio controller, the same chip as found in last year's 21.5"
Image #1 Image #2
Add Note Edit Step 24  ¶
  • So, ummm...
  • See these traces on the board here?
  • See this other hole on the left?
  • Looks like this is where Apple's proprietary SSD connector should reside.
    • Placing the SSD from the 13" MacBook Pro Retina Display confirms this notion. If the shoe fits...
  • We purchased the "bargain-basement" version of the iMac. We're assuming that the more-expensive version—one that has the built-to-order Fusion drive option—has this connector soldered onto the board, and a 128GB SSD placed into said connector.
  • Looks like there'll be no love for our awesome dual-drive kit from this iMac generation. :(
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 27 In stock
T10 Torx Security Bit Screwdriver
$6.95 · 48 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
SATA Wondercable USB Adapter
$29.95 · 24 In stock
iMac Service Wedge
$12.95 · 1 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 10 In stock
