first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • Some interesting features of the board include:
    • 64 MB Hynix HY5DU121622BTP CMOS Double DataRate (DDR) Synchronous DRAM
    • GL8520G USB 2.0 Hub
    • MMA7455 3-axis accelerometer
    • QN8005B FM radio
    • Blank space for NAND flash (not used due to booting from MicroSD)
    • MicroSD socket complete with a 2GB Kingston MicroSD firmware card
    • Unpopulated passives for composite (NTSC/PAL) video output
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • Now, back to disassembling the chassis...
  • A simple tug removes the Ralink-based RT2571 USB Wi-Fi dongle.
    • The Ralink RT2571 supports both USB 1.1 & 2.0 for 802.11 a/b/g connectivity.
    • The chipset has the capability to operate in Windows XP, 2000, ME, 98SE, and in Linux.
  • Considering the open source nature of the chumby, wireless internet can conceivably be sacrificed for the extra USB port housing the Wi-Fi dongle.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Get your groove on with the single 2W mono speaker mounted flush in the plastic chassis.
  • After removing the four Phillips screws securing the speaker to the chassis, use a sharp blade to carefully separate the speaker cables from the adhesive applied near the speaker opening.
    • The speaker wires are glued down to avoid any rattling noises from ruining your air guitar solo.
  • The speaker has a 7/8" concave aluminum diaphragm held to the frame with a foam rubber surround.
  • The white panel on the chassis is fitted with a conical port presumably to eliminate resonance.
first image
Add Note Edit Step 12  ¶
  • Alas, we have reached the end of our endeavors. Good-bye chumby one, you will always be remembered as the one we tore apart...
  • Shameless plug: If your Apple product is suffering from any hardware-related ailments, use our site to fix it!
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Metal Spudger
$2.95 · 50+ in stock
Plastic Opening Tools
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
1.5" Thin Putty Knife
54 Bit Driver Kit
T5 Torx Screwdriver
$9.95 · 50+ in stock
Home Tech Toolkit
Notes Add Note Notes are offturn on
