iFixit
Add Note
chumby one Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Lately, there's been much talk by the office water cooler about this all-in-one embedded device. It combines internet, LAN access via a Wi-Fi, and, oh yeah, it's also an alarm clock... It goes by the name of chumby one.
The chumby one is a completely open source platform, and the developers encourage all you hackers to dig right into the source code.
What follows is not for the faint of heart. You have been warned....
Check out the YouTube video slideshow of the teardown!
View: Paginated Full width Slideshow
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — chumby one Teardown
  • Welcome to another exciting edition of our popular teardown series.
  • Today's contender hails from the land of chumby industries, inc..
  • Measuring 4" wide x 4" tall x 3.5" deep, boasting an impressive 3.5" LCD color touchscreen, and a beefy 454 MHz ARM processor, it is our pleasure to welcome the chumby one to the grandest stage in all electronic dismemberment.
  • The chumby one combines all the greatness the internet has to offer. It integrates weather, news, music, videos, photos, social networking sites, and more with an extensive array of more than 1500 widgets in more than 30 categories.
  • That's all gravy and everything, but how's it look inside?
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2
  • First use a thin metal spudger to remove the four self-adhesive plastic dots covering the screw holes.
  • Remove the four Phillips screws holding the cases together. You'll need a thin-shafted screwdriver to remove them.
  • Ventilation holes abound in the top and rear outer cases. Such a Swiss cheese case design allows the chumby to cool off without the need for a fan.
  • There are no screws in the bottom case; it is held in place when the cases are fastened together.
  • Pull the rear case away from the chumby to reveal the spiffy internals.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3
  • Slide the lower case away from the front of the chumby, then tilt it away from the logic board to reveal the battery connector. Taking as many precautions as possible, we decided to disconnect the battery connector from the logic board assembly.
  • Use a plastic opening tool to dislodge the plug of hot glue holding the FM antenna wire in the lower case. At this point you can de-route the FM antenna wire and remove the lower case from the chumby.
  • chumby industries, inc. recommends using only a Fujifilm NP-120 battery.
    • The NP-120 is a rechargeable Lithium-Ion camera battery. The chumby is equipped with circuitry to charge the battery when it is plugged into AC power.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4
  • Use a pair of tweezers to pull the microphone connector away from the front of the chumby.
  • Use a plastic opening tool to pry up the ZIF lock on the display ribbon cable socket.
  • Pull the display ribbon cable out of its socket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5
  • The volume knob is simply pressed onto the splined volume control shaft.
  • Use a plastic opening tool to pry evenly around the edge of the volume knob until you can remove it from the chumby.
  • Volume control commands are sent via a rotary encoder that translates angular degrees of rotation into binary code recognized by the board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6
  • After removing four Phillips screws securing the inner chassis to the outer case, the guts can be removed in one piece.
  • Controls are routed through two daughterboards; one houses the two push-button elements and the other holds the volume dial.
  • The wireless card is attached to a small interconnect board, converting the four-pin connector found on the logic board into the USB connector used by the wireless card.
  • After a bit too much wiggling, we broke the FM antenna lead where it attaches to the board. Soldering iron to the rescue!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7
  • Next, remove the four Phillips screws securing the display to the outer case.
  • Lift the display and its metal shield out of the front case and bask in its 320x240 magnificence.
    • The display element is a 3.5", 320x240 pixel, 16 bits-per-pixel thin-film transistor (TFT) LCD.
    • The touchscreen element and the LCD both connect to the logic board through the same ribbon cable.
  • The outer edge of the glass touchscreen element is stuck to the outside of the LCD. It seems like dust and lint would have a hard time finding their way in between the two pieces.
  • As much as we love playing with sharp objects, we weren't brave enough to mix glass and exacto blades while trying to remove the touchscreen element.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8
  • Carefully pull the logic board away from the inner chassis. As you pull the board away, be sure not to bend the pins on the Wi-Fi and volume knob interconnect boards.
  • After separating the two pieces slightly, disconnect the button panel and the speaker connectors from the logic board.
  • Hey look, a MicroSD card!
  • A row of sockets near the MicroSD socket provide connectivity for a TTL-level 115200, 8N1 serial console.
  • A message from the designer. How cute.
Next » « Previous
Tools
Tool image
Metal Tweezers
$2.95 · 54 in stock
Tool image
Plastic Opening Tools
$2.95 · 83 in stock
Tool image
Metal Spudger
$2.95 · 144 in stock
Tool image
Phillips #00 Screwdriver
$4.95 · 633 in stock
Popular Repair Guides
Blurb image
Installing iPhone 3GS Headphone...
No audio? Replace the headphone...
79 recent views
Blurb image
Installing iPad 3G Ambient Light...
Replacing the ambient light sensor.
76 recent views
Blurb image
Installing PSP 3000 LCD Screen
Guide for replacing the LCD...
66 recent views
Blurb image
Installing iBook G4 14"...
You can install hard drives up...
54 recent views
Notes Add Note Notes are off | turn on
