This teardown is not a repair guide. To repair your Acer Aspire One 725, use our service manual.
  1. acer aspire one 725 Teardown, This is an acer aspire one: step 1, image 1 of 3 acer aspire one 725 Teardown, This is an acer aspire one: step 1, image 2 of 3 acer aspire one 725 Teardown, This is an acer aspire one: step 1, image 3 of 3
    • prepare you're self for a lot of screws
  2. acer aspire one 725 Teardown, Remove the battery: step 2, image 1 of 3 acer aspire one 725 Teardown, Remove the battery: step 2, image 2 of 3 acer aspire one 725 Teardown, Remove the battery: step 2, image 3 of 3
    • on the top right corner and slide it to the right
    • It release very easily
  3. acer aspire one 725 Teardown, Getting inside the laptop: step 3, image 1 of 3 acer aspire one 725 Teardown, Getting inside the laptop: step 3, image 2 of 3 acer aspire one 725 Teardown, Getting inside the laptop: step 3, image 3 of 3
    • There's a screw natural reaction unscrew it
    • Slide the cover right off
  4. acer aspire one 725 Teardown, Removing the ram: step 4, image 1 of 3 acer aspire one 725 Teardown, Removing the ram: step 4, image 2 of 3 acer aspire one 725 Teardown, Removing the ram: step 4, image 3 of 3
    • Simply push these pins out and it'll come out
    • It's kinda fun to taking it out and pushing it back in
  5. acer aspire one 725 Teardown, Removing the hard drive: step 5, image 1 of 3 acer aspire one 725 Teardown, Removing the hard drive: step 5, image 2 of 3 acer aspire one 725 Teardown, Removing the hard drive: step 5, image 3 of 3
    • More screws unscrew them
    • It might be hard to removing the hard drive so use the screwdriver to push it out
  6. acer aspire one 725 Teardown, Still removing the hard-drive: step 6, image 1 of 3 acer aspire one 725 Teardown, Still removing the hard-drive: step 6, image 2 of 3 acer aspire one 725 Teardown, Still removing the hard-drive: step 6, image 3 of 3
    • This is what it should look like
    • You can also change the hard-drive if you want by unscrewing the metal piece
  7. acer aspire one 725 Teardown, Just a look: step 7, image 1 of 1
    • to see how it looks like
  8. acer aspire one 725 Teardown, Before removing the keyboard: step 8, image 1 of 2 acer aspire one 725 Teardown, Before removing the keyboard: step 8, image 2 of 2
    • Please remove the black and blue strip
    • These are connected to the keyboard
    • Also unscrew all the screws keeping the panel down
  9. acer aspire one 725 Teardown, Removing the keyboard: step 9, image 1 of 2 acer aspire one 725 Teardown, Removing the keyboard: step 9, image 2 of 2
    • pry it open by where the battery was
    • These show the mother board
    • There are multiple screws, black screws and sliver screws
    • I labeled black screws with red. I labeled the sliver screws with yellow.
  10. acer aspire one 725 Teardown, The touch pad: step 10, image 1 of 3 acer aspire one 725 Teardown, The touch pad: step 10, image 2 of 3 acer aspire one 725 Teardown, The touch pad: step 10, image 3 of 3
    • There is a purple strip and unhook it
    • Take off the panel that the blue and purple strip its connected to
  11. acer aspire one 725 Teardown, The key board separated: step 11, image 1 of 2 acer aspire one 725 Teardown, The key board separated: step 11, image 2 of 2
    • A look of the key board
  12. acer aspire one 725 Teardown, So far we gone: step 12, image 1 of 3 acer aspire one 725 Teardown, So far we gone: step 12, image 2 of 3 acer aspire one 725 Teardown, So far we gone: step 12, image 3 of 3
    • I know that we didn't take apart the mother board but this is all that
    • I hope that you find this useful
Poua Yang
171 Reputation
1 Guide authored
2 Comments
thanks !!!! a lot
alej689 - Reply
Great guide, Thanks.
Do you know if there is a lithium battery (coin shape) ? or a jumper for BIOS password resetting ?
Nico Land - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 3,737
