This teardown is not a repair guide. To repair your ZTE Z432, use our service manual.
  1. ZTE Z432  Teardown, Start here!: step 1, image 1 of 1
    • This is the ZTE Z432 I'll be tearing down. Make sure the device is powered off before continuing.
  2. ZTE Z432  Teardown, Back panel, battery and SIM card: step 2, image 1 of 2 ZTE Z432  Teardown, Back panel, battery and SIM card: step 2, image 2 of 2
    • The back panel is held on with plastic clips, which you can use an opening pick or your finger to unclip to remove the back panel from your phone. Now you will need to remove the battery, SIM card, and microSD card if you have one.
  3. ZTE Z432  Teardown, Front panel: step 3, image 1 of 2 ZTE Z432  Teardown, Front panel: step 3, image 2 of 2
    • Remove the 7 P0 phillips screws under the rear cover. Then, some careful prying is required to seperate the back and front panels. This can be achieved with a large plastic opening tool. The front panel contains the keypad and power/volume buttons, which can be removed.
  4. ZTE Z432  Teardown, Rear panel and logic board: step 4, image 1 of 1
    • Just carefully pry the logic board and back panel apart. That's all there is to it.
    • The board is pretty much one unit, including the screen.
  5. ZTE Z432  Teardown, Conclusion: step 5, image 1 of 1
    • Here is all of the parts laid out. To re-assemble, follow the guide in reverse order.
nerdbug96
1,462 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 343
