This teardown is not a repair guide. To repair your ZTE T81, use our service manual.
  1. ZTE T81 Teardown, Remove the back cover, SIM card, battery and SD card: step 1, image 1 of 1
    • Remove the back cover, SIM card, battery and SD card.
  2. ZTE T81 Teardown, Remove the screws: step 2, image 1 of 2 ZTE T81 Teardown, Remove the screws: step 2, image 2 of 2
    • Remove the 9 screws under the back cover. The top left screw is covered by a white "warranty void" sticker.
  3. ZTE T81 Teardown, Separate the frame from the mainboard: step 3, image 1 of 2 ZTE T81 Teardown, Separate the frame from the mainboard: step 3, image 2 of 2
    • Separate the frame from the mainboard
    • Pry apart the frame with the battery holder and camera housing from the mainboard of the phone.
  4. ZTE T81 Teardown, Remove the front glass.: step 5, image 1 of 2 ZTE T81 Teardown, Remove the front glass.: step 5, image 2 of 2
    • Remove the digitizer cable and separate the digitizer/front glass from the rest of the phone.
  5. ZTE T81 Teardown, Remove the LCD screen: step 6, image 1 of 3 ZTE T81 Teardown, Remove the LCD screen: step 6, image 2 of 3 ZTE T81 Teardown, Remove the LCD screen: step 6, image 3 of 3
    • Unplug the LCD screen from the mainboard and carefully peel the display off the mainboard. It is only stuck on.
  6. ZTE T81 Teardown: step 7, image 1 of 2 ZTE T81 Teardown: step 7, image 2 of 2
    • Insert wisdom here.
domenicofavotto1
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,300
