ZEN V Creative Media Player Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
A quick and easy teardown/disassembly guide for the ZEN V Creative Media Player.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — ZEN V Creative Media Player Teardown  ¶
  • Here we have Creative's ZEN V Media Player.
    • The Navigator Stick
    • The Play/Pause Button
    • The Back Button
    • The LCD
    • USB 2.0 Charging Port
    • Headphone Jack
    • Line In Jack
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Start by taking a pointy metal spudger and insert it on the bottom edge of the player
  • Slide it along, prying up until a gap forms
  • Proceed to insert and slide the tool along the left and right side of the device, until the plastic piece with the buttons comes free.
  • Half of the covering plastic should be off now
    • Gap between plastics
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • While doing the following steps note that this piece is glued on to the LCD. Do not apply too much force or shove your tool too far in
    • Glue
  • Bring your tool to the top edge of the player and insert it
  • Insert it on the top edge and slide while prying up
    • The gap
  • Insert it on the two sides and pry until plastic comes loose
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Be very gentle with the LCD in the next 2 steps! It is glued to the logic board with black stick pads. Do not break the cable/clip!
    • Adhesive Pads
    • Cable Clip
  • Insert flat end of plastic spudger on the bottom of the LCD. Pry gently upwards.
    • Bottom of LCD
  • Insert on the sides and continue to pry.
  • Finally insert on the top and pry.
    • Top of LCD
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Pull back LCD to bottom of player to expose cable/clip
  • Remove orange ESD safe tape with spudger/fingernail
    • Orange ESD safe tape
  • Flip up the clip with flat end of spudger/fingernail
    • Clip is flipped up
  • Pull the LCD away from the player
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Put down your spudger and pick up a Phillips #000 Screwdriver
  • Remove the two screws on the logic board
    • Screws
  • Remove Volume control button by pulling it up off the board
    • Volume control button
  • Pull up board from bottom of player
  • Gently wiggle the logic board out of the casing. Be careful because it is connected to a battery underneath it
    • Battery
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Insert spudger under the top of the battery and pry
    • Top half of battery
  • There is an adhesive pad under the battery
  • Battery should now be free
  • Remove battery from case and set aside connected to the logic board
first image
Add Note Edit Step 8  ¶
  • Battery may now be removed from logic board with a soldering iron
  • Heat up the contacts and pull away wires
    • Contacts
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • These all are various components that can be removed with a soldering iron
    • USB 2.0 Port has 4 pads and 5 pins attaching it to the logic board
    • Various Switches- 4 pads each. From the (Bottom left), Volume up, Volume Down, Mute?, (Top Left), Power on/Hold, Reset
    • Line In Jack 4 pads
    • Headphone Jack 4 pads
    • Play/Pause Button 2 pads and Back Button 2 pads
    • LCD connector and Navigtor button
first image
Add Note Edit Step 10  ¶
  • All the innards of the ZEN V Media Player
    • Button Plastic- Removed in Step 2
    • LCD Plastic- Removed in Step 3
    • Orange ESD Safe tape and LCD Screen- Removed in Step 5
    • Screws and Volume Button- Removed in Step 6
    • Back Plastic Case and Logic Board- Removed in Step 7
    • Battery Removed in Step 8
Notes Add Note Notes are offturn on
