Xbox 360 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
The Microsoft Xbox 360 released in 2006, is one of the most powerful gaming consoles on the market. This console has taken a lot of heat over the years because of the red ring of death, But I'll show you what's inside of this beast.
Tools (continued)
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Xbox 360 Teardown  ¶
  • The Xbox 360 is one of the most powerful gaming consoles on the market. I may have the Halo 3 Edition, but the dissasembly for all models is the same.
  • The disaassembly of this console is not easy, but with some patience you can do it.
  • This Disassembly also works with HDMI models, and Non-HDMI models
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Begin by removing the hard drive, (skip this step if your console doesn't have a hard drive)
  • Press the button on the hard drive, then pull up near the front. Once the front is removed, slide the drive forward and then lift the drive out.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Removing the Face-Plate
  • Put two fingers into the USB port area, then push down, while pulling the face-plate towards you.
first image
Add Note Edit Step 4  ¶
  • Not so pretty anymore!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Removing The Top Bezel
  • Make sure the console is standing up. Then look into the grill.
  • The red circles mark the location of tabs (like this on the other side too). Together there are 6. To pull off the top grill, use a small round object to insert into the holes onto the tab, then pull up on the grill, freeing it partially. You need to do this to all 6 tabs to ensure you don't break them. Then lift the grill up. This process is the same for the top and bottom.
  • The Tabs Are Circled In Yellow
  • As you can see, I got lazy and broke two of them. Try not to do the same, yet as long as most of the tabs are there, it should still go back on. So don't sweat it, if you break them.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • The Bottom Grill
  • Flip the console over, and remove the bottom grill the same way you removed the top one.
  • Once you are done removing the grills, both the top and the bottom should look like this.(3rd Photo)
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • The Point of No Return
  • That little thing that I am pointing at, with a screwdriver, is the "Microsoft Seal". It is a sticker that you must remove to continue. It is the warranty sticker. Mine has already been removed, and once you remove it, you will see why you can't put it back on. This is the point of no return, but if you heat it up a little, you can certainly reduce this
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Once you break the Microsoft seal, we can continue. Start by taking multiple flathead screwdriver bits or 4 spudgers (The most common spudger is a black or yellow nylon stick with a metal hook at one end.) and put them in these 4 latches to hold them open.
  • After all 4 tabs are held open, pull up on the top half of the case. The bits should pop out(don't lose them!). Lift the case up and make sure the tabs don't reconnect.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • Lift the half up and then flip the console upright, and make sure that you don't let the tabs close.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Removing the bottom half.
  • This next step is hard, but I promise that the bottom half comes off.
  • Using a small flathead screwdriver, pry these tabs apart. It's hard to show how to remove the clips, but you'll see soon enough.
  • Using a flathead screwdriver, pop out all 7 tabs. It's hard to do this without causing some damage to the casing.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Removing the bottom/right half.
  • These pictures should explain how it's done.
  • Once all tabs are free, flip the console back over and lift the bottom half off.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Removing the Top Half
  • Using a small flathead screwdriver, or a spudger, remove the eject button assembly.
  • It should come off easily, but some models have adhesive, making the process slightly harder.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Removing the top half.
  • Flip the console over and remove the 6 T10 Screws. They should each be 3" long, if not, you removed the wrong screws.
  • Then flip the console back over, holding it by both the plastic and the metal.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • Now lift the top half off, and Voila! You now have access to the guts.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • Removing the DVD Drive.
  • It is a SATA DVD drive with a proprietary Xbox power connector.
  • Lift the drive up near the back revealing the connectors.
  • Remove both the power and SATA cables from the drive. Be careful when doing this, the connectors are fragile.
  • Pull the drive out of the console. There may be tape on the front of the drive holding it in, remove the tape.
  • Set the drive aside.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
  • Removing the Fan Shroud.
  • Using a flathead screwdriver, pry out the tab connecting it to the fans.
  • Lift the shroud out.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 17  ¶
  • Removing the Fans.
  • Remove the 3-Pin power connector from the logic board. This is the same connector used in some PC fans.
  • Using a flathead screwdriver, pry the fans toward you.
  • Pull the fans toward you, then lift them out of the casing.
first image
thumb image 1
thumb image 2
Add Note Edit Step 18  ¶
  • Removing the Fans
  • Here are pictures of the fans and power connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 19  ¶
  • Removing the "Ring Of Light"/RF board.
  • Pop off the plastic LED cover.
  • Remove these 3 T8 Screws
  • Pull the board toward you. Than set it aside.
first image
Add Note Edit Step 20  ¶
  • Removing the logic board.
  • Remove these T10 Screws from the bottom metal casing, there may be more than the number circled, just remove them all.
  • If they are present, remove these T8 Screws from the bottom metal casing.
  • Flip the casing over.
  • With a little persuasion, the logic board should lift out of the casing.
first image
Add Note Edit Step 21  ¶
  • The Logic Board: This is a logic board with advanced cooling for the GPU(often known as a "Falcon" Board) Unfortunately, I couldn't find my T8 Bit. so I can't show you the bottom of the logic board, or under the heatsinks, but hopefully, I will be able to finish this teardown completely in the future.
  • Here is a shot of the logic board.
  • Custom ATi Graphics Processor with 10Mb of video Ram
  • 3 IBM PowerPC Cores Each Running At 3.2Ghz with 512Mb of System Ram
  • Memory Card Ports
  • Hard Drive Port
  • HDMI and Video Ports
  • Power Port
first image
thumb image 1
thumb image 2
Add Note Edit Step 22  ¶
  • The Guts!
