This teardown is not a repair guide. To repair your Ubee DVW23C, use our service manual.
  1. Ubee DVW23C Teardown, Ubee DVW23C Teardown: step 1, image 1 of 3 Ubee DVW23C Teardown, Ubee DVW23C Teardown: step 1, image 2 of 3 Ubee DVW23C Teardown, Ubee DVW23C Teardown: step 1, image 3 of 3
    • As we look around the device, the only visible screws are 4 on the back, and one by the power connector.
    • All the screws so far are T10 Torx.
  2. Ubee DVW23C Teardown: step 2, image 1 of 2 Ubee DVW23C Teardown: step 2, image 2 of 2
    • Prying away the front panel reveals the inside.
  3. Ubee DVW23C Teardown: step 3, image 1 of 2 Ubee DVW23C Teardown: step 3, image 2 of 2
    • The PSU is red
    • The Broadcom chip is orange.
    • The DOCSIS Cable connector is yellow
    • The PSU Connector is green
    • The Antenna connectors are blue
    • The lights and diffusers are light blue
    • The ethernet and telephone jacks are magenta
  4. Ubee DVW23C Teardown: step 4, image 1 of 2 Ubee DVW23C Teardown: step 4, image 2 of 2
    • The PSU comes out with one screw, and the power connector screw.
    • It is the N12-035N1A Power Supply from Chicony Power.
  5. Ubee DVW23C Teardown: step 5, image 1 of 2 Ubee DVW23C Teardown: step 5, image 2 of 2
    • Finally, removing the motherboard shows what it looks like on the back.
  6. Ubee DVW23C Teardown, Conclusion: step 6, image 1 of 3 Ubee DVW23C Teardown, Conclusion: step 6, image 2 of 3 Ubee DVW23C Teardown, Conclusion: step 6, image 3 of 3
    • In conclusion, this is one of the more repairable modem/router combos, especially since it's from an ISP.
    • All the screws are the same, and while the T10 isn't user-friendly, it's easy to find online and in stores, and having a unified screw simplifies the repair process.
    • The PSU is completely easily replaceable, but is unfortunately custom made for this model, and not found online.
    • So while it's easy to open, it isn't easy to find replacement parts.
    • Backups are also downloaded unencrypted, unfortunately, and with no way to update the firmware, it won't get fixed. The backups contain both your password, and the technician password (Username: technician / Password: C0nf1gur3Ubee#) inside the file.
9021007
4,599 Reputation
25 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,156
