Toshiba Satellite A215 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Toshiba Satellite A215 Teardown  ¶
  • Remove the battery
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Loosen this screw, and pop out the RAM cover.
  • Undo the module clamps, gently lift the end of the module to a 45-degree angle and pull it out. Do the same for the one below.
    • Make sure not to expose the memory to any static electricity whatsoever, ground yourself before handling it by either touching an unpainted metal surface or wearing an anti-static bracelet.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Loosen these 3 screws, and pop out the two hard drive bay covers
  • Pull out the plastic tab located here, and pull it gently but firmly to the right.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Remove this screw, it might require tweezers after loosening to get out.
  • Insert a paper clip into this hole, which will pop out the drive
    • Grasp the drive tray and gently but firmly pull it out of the laptop chassis.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Remove these screws
    • Flip the laptop over, and push the bezel towards the lcd while lifting up, this might require some force.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Remove the two screws at the top of the keyboard
    • Guide the keyboard towards the LCD, and lift up slightly, be careful of the ribbon cable underneath
    • Using a spudger or fingernail, carefully push one side, then the other of the keyboard ribbon connector toward the LCD, releasing it.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Remove the 2 screws on the bottom of the laptop
    • Disconnect the LCD cable and thread it out of its path so it's free
    • Using a spudger or fingernail pop off the two wifi antennas and thread them out too
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Remove the four screws on the LCD hinges
  • Lift the display panel up and out
Next » « Previous
