This teardown is not a repair guide. To repair your T-Mobile Huawei Prism U8651T, use our service manual.
  1. T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: step 1, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: step 1, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: step 1, image 3 of 3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Teardown, Remove Battery: step 2, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Battery: step 2, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Battery: step 2, image 3 of 3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T Teardown, Torx Screws: step 3, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Torx Screws: step 3, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Torx Screws: step 3, image 3 of 3
    Tool used on this step:
    T4 Torx Screwdriver
    $5.99
    Buy
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: step 4, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: step 4, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: step 4, image 3 of 3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T Teardown, Remove Power and Volume Buttons: step 5, image 1 of 2 T-Mobile Huawei Prism U8651T Teardown, Remove Power and Volume Buttons: step 5, image 2 of 2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: step 6, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: step 6, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: step 6, image 3 of 3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: step 7, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: step 7, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: step 7, image 3 of 3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: step 8, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: step 8, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: step 8, image 3 of 3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: step 9, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: step 9, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: step 9, image 3 of 3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: step 10, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: step 10, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: step 10, image 3 of 3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T Teardown, Remove Screen: step 11, image 1 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Screen: step 11, image 2 of 3 T-Mobile Huawei Prism U8651T Teardown, Remove Screen: step 11, image 3 of 3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
  12. T-Mobile Huawei Prism U8651T Teardown: step 12, image 1 of 1
    • Teardown complete
Dillon
578 Reputation
5 Guides authored
Michigan Tech, Team 1-7, Lauer Fall 2014 Member of Michigan Tech, Team 1-7, Lauer Fall 2014
MTU-LAUER-F14S1G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 13
All Time: 2,348
