Suzuki FA50 Moped Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
My 1984 Suzuki FA50 was exhibiting some interesting problems. Although it ran fine a year ago, I could not get it running for the life of me. The problem was most likely a stuck throttle cable that I unstuck using some brute force. However, I figured it would also be nice to get my hands dirty and do an overhaul of the carburetor and engine. So here it is!
Note: The teardown was done backwards. I already disassembled the moped, and then took pictures reassembling it together. You may notice that some parts look new -- it's because they are.
Note #2: I figured it would be good to ring in the new year with a solid teardown, so I published it right on 12:00 AM PST, January 1, 2010 :)
first image
Add Note Edit Step 1 — Suzuki FA50 Moped Teardown  ¶
  • There's no rage against this machine.
  • Looks great, except it doesn't run.
  • Its 50 cc engine lets me go downhill at almost 28 MPH when it does run. Uphills, not so much. Depending on the hill (and my head start), I may or may not have to walk it up.
    • The seat advertises "185 LB max." In the USA??
    • The above weight limit can be used in a "Yo mamma" joke. Note that I said can be, and not should be.
first image
Add Note Edit Step 2  ¶
  • Safety first. Disconnect the battery and store it in a safe place.
  • The battery's readily accessible underneath the seat.
first image
Add Note Edit Step 3  ¶
  • In retrospect I figured out i that I didn't need to remove the exhaust cover, but what the heck... When in Rome, right?
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Took off the air intake box.
  • That's contractor-grade 3M packing tape holding the airbox together. Only the best for my moped.
first image
Add Note Edit Step 5  ¶
  • I went to the other side of the bike and removed the carb/oil pump protective cover.
first image
Add Note Edit Step 6  ¶
  • The foot rest came off next, in order to gain access to the engine and spark plug.
first image
Add Note Edit Step 7  ¶
  • While down there, I unplugged the spark plug cover.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • I then proceeded to access the wiring underneath the gas tank.
  • The wires needed to be disconnected in order to remove the frame away from the engine/crankshaft.
  • First I removed the protective brace on top of the oil/gas tanks using a 10 mm socket wrench.
Next » « Previous
