PlayStation 2 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
At first, I will apologize for my poor English, I am from Brazil, but I love this site, especially because I have loved to disassemble electronic stuff since I was a kid. My mother always freaks out, but I always assemble everything back. Sometimes I even fix some things.
I'm writing this teardown to try to win the PSP GO or the Ps3 slim, so please look with care, it was made with care.
In this teardown I will show how to disassemble my Sony Playstation 2. I already made it sometimes , to clean it up and to fix a small problem.
And later in the Repair area, I will show how I fix a small Problem in it. I sent it to a technician because the rumble effect was no longer working. He says that there was a problem in the motherboard and he needs to change it entirely. But the model is a SCPH 39001, an old model, one of the first in the market. He says that the price of the fix was prohibitive and said that is better buy a new PS2 Slim, that nowadays is cheaper. I remember when a bought my Ps2, it costs more than R$800, almost US$400. I decide to stay with it anyway and despite the problem I even bought a Ethernet adapter to continue playing it.
Later, talking with some friends, I knew that is a fuse that controls the rumble effect and all that I need to do is to change it. But the fuses in the mainboard are too small , fixed in the main board and is impossible to change it. The same friend give me a tip, that I can use a glass fuse and take the internal wire to use in the main board. I decide to try and it works perfectly.
So, lets start the teardown, enjoy.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — PlayStation 2 Teardown  ¶
  • Here we have the system console fully assembled.
  • The USB Ports.
  • The S400 ports, that nobody uses.
  • Here we have the DVD Drive
  • The reset button
  • The eject button
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • This are the only tools that we need. 4 screwdrivers and a tweezer.
  • In the next photo, the console, the joystick, the wires and a memory card.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • In the Back, in this case we have a Ethernet adapter, to play online and to use with a Hdd.
  • And the cooler,
  • The power switch
  • The AC in.
  • The Av out
  • And the digital output (optical)
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Lets start the teardown. At first we use a flathead screwdriver to remove the ethernet adapter.
  • Remove these 2 screws
  • And is quite simple to pull.
first image
Add Note Edit Step 5  ¶
  • This is the expansion bay, where we put the Hdd.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Turn the console upside down.
  • Using a small flathead screwdriver, remove the screw protections. In this model we have 8 of them.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Under the protection, suprise! a screw!
  • You'll have to remove the eight.
  • Yes, hard work!
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Put the console in the normal horizontal position, and pull the top cover from back to front.
  • Look the images!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • This model have a flat cable to the reset and eject button. Take extreme caution to not destroy it.
  • Remove the button structure just pulling wiht a small flat screwdriver.
first image
Add Note Edit Step 10  ¶
  • The button structure comes out of the case. It have some tape to prevent a new destruction. Yes, I already destroyed this flat cable.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Remove this two screws to deatach the controller port.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Here we remove the screws from the cooler and the main power switch
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Pull the cooler up, but take care to not destroy de wire.
  • Pull up the fan grid.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • The power cable go to inside the case. Is better let to remove in a further step.
  • The fan wire also go to inside the case. Take extreme care to not destroy it.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • Lets turn the console upside down again, with caution because the pieces are locked, and just in the next step we can remove them.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
  • Lets remove the bottom case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 17  ¶
  • This is the power source board. remove the 4 screws where I marked in blue.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 18  ¶
  • Looking from the back, pull up the board, releasing from the pins of the main board.
  • Finally you can remove the power switch.
  • And this is the power source board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 19  ¶
  • Now we remove the expansion bay grid.
  • And now is the time to remove the fan wire from the main board, using a precision tweezer. But.. I can't, it simply stucks. I already remove this ealier, but now is harder, I will try later, in the end of the teardown.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 20  ¶
  • Remove the isolation cover from the metal case.
  • Remove the small screws using a thin crosshead screwdriver.
  • And release the metal case from the DVD player, as indicated, using a small flat screwdriver
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 21  ¶
  • Now you can remove the metal case, and find the main board.
  • Look the flat cables. Now is the time to remove them. Be gentle.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 22  ¶
  • There is 2 more and the DVD player is free.
first image
thumb image 1
thumb image 2
Add Note Edit Step 23  ¶
  • Now you can turn upside down again, and remove de metal protection.
  • This is the other side of the main board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 24  ¶
  • Well, the try to remove the cooler wire was a total failure.
  • The plug is made to deatach, but like is old, it turn into a one piece, and break the soldering.
  • Well, I'll find a way to fix it. I always do =)
first image
Add Note Edit Step 25  ¶
  • This is the end of the teardown.
  • From top, from the left: Ethernet adapter, Ps2 case, Hdd, Cooler, Cooler grid, bottom metal cover protection, screws protectors, screws, Controller board, Power swtich, Power source board, Plastic cover to isolate the power source board, top metal cover, DVD Drive, Expansion Bay cover, main board, reset/eject structure.
first image
Add Note Edit Step 26  ¶
  • bonus! a contribution to iFixit, my tripod made of a music stand and nylon clamps. =)
Notes Add Note Notes are offturn on
