first image
Add Note Edit Step 9  ¶
  • Remove the RAM.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • Remove the RAM.
  • Remove the hard drive metal bracket. Mine had 2 screws but I believe there are supposed to be 4 (lost them when I replaced the hard rive last time). Disconnect ribbon from motherboard.
  • Remove the wireless card. There are 2 antennas connected to it, the back wire goes on the main, gray on aux.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Remove one screw form the sound card. Disconnect one ribbon and one connector (under) from card.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Remove the DVD drive by unscrewing 5 screws, make sure to open the drive with the paper clip to access the last one.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Remove one screw from the network/modem combo card. Disconnect 3 connectors and one ribbon from cards. There is an additional connector on the motherboard.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • Time to remove the screen. Remove 2 screws holding the hinges down
  • Remove ground screw and wire.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • Remove 4 bezel screw covers. Remove 4 screws.
  • Remove 2 caps from hinges. Remove bezel.
  • Remove 4 screws holding screen. Disconnect one connector from the power module
first image
Add Note Edit Step 16  ¶
  • Disconnect one ribbon from the back of the screen.
Next » « Previous
Required Tools
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ in stock
Phillips #1 Screwdriver
$8.95 · 13 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
iPhone 3GS Front Panel Kit
$39.95 · 38 in stock
iPhone 3GS Replacement Battery
$19.95 · 50+ in stock
Small Suction Cup
$2.95 · 50+ in stock
Precision Tweezers Set
$7.95 · 28 in stock
Notes Add Note Notes are offturn on
