Sony Vaio VGN-T140P Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
As part of the Sony giveaway, I would like to contribute with this VAIO teardown. Bear with me as this is my first tutorial. This is a VGN-T140P 12” wide screen laptop with an Intel Pentium M 1.10G processor, 1G RAM and a 40G hard drive. It’s an oldie that still does the job. Well let’s get to the teardown.
first image
Add Note Edit Step 1 — Sony Vaio VGN-T140P Teardown  ¶
  • Let's start with the tools and the victim...
first image
Add Note Edit Step 2  ¶
  • Remove the battery by moving the 2 release tabs.
first image
Add Note Edit Step 3  ¶
  • Remove 3 screws holding the keyboard.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Loosen 2 latches holding the keyboard down with the flat tip screwdriver, one by the F5 key, and the other by the Num Lock key. Move keyboard towards the touch pad and pull up.
  • Remove the ribbon carefully.
  • I added this step separate for the ones that just want to upgrade the RAM.
first image
Add Note Edit Step 5  ¶
  • Remove 8 screws under the computer.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the power button and cap on opposite side.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Remove one screw from top and one from under cap opposite of the power button.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Unsnap the top cover carefully around the edges.
  • Disconnect 3 ribbons and pull top carefully towards the left side. Remove ribbon from the motherboard.
first image
Add Note Edit Step 9  ¶
  • Remove the RAM.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • Remove the RAM.
  • Remove the hard drive metal bracket. Mine had 2 screws but I believe there are supposed to be 4 (lost them when I replaced the hard rive last time). Disconnect ribbon from motherboard.
  • Remove the wireless card. There are 2 antennas connected to it, the back wire goes on the main, gray on aux.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Remove one screw form the sound card. Disconnect one ribbon and one connector (under) from card.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Remove the DVD drive by unscrewing 5 screws, make sure to open the drive with the paper clip to access the last one.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Remove one screw from the network/modem combo card. Disconnect 3 connectors and one ribbon from cards. There is an additional connector on the motherboard.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • Time to remove the screen. Remove 2 screws holding the hinges down
  • Remove ground screw and wire.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • Remove 4 bezel screw covers. Remove 4 screws.
  • Remove 2 caps from hinges. Remove bezel.
  • Remove 4 screws holding screen. Disconnect one connector from the power module
first image
Add Note Edit Step 16  ¶
  • Disconnect one ribbon from the back of the screen.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 17  ¶
  • At last, the motherboard. Remove 2 screws holding a plastic bracket down.
  • Disconnect the ribbon connector and remove 3 screws.
first image
Add Note Edit Step 18  ¶
  • Remove the memory stick reader.
first image
Add Note Edit Step 19  ¶
  • All done! Sorry for the crappy picture.
  • Just in case you are wondering, is back together and working like a champ.
