Sony Vaio FZ Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
My Vaio FZ recently got hot and its fan was working loud. I decided to tear it down and remove the 2-year-old dust:)
first image
Add Note Edit Step 1 — Sony Vaio FZ Teardown  ¶
  • First, unplug the laptop and remove the battery.
  • Remove the marked screws.
first image
Add Note Edit Step 2  ¶
  • Remove the covers for HDD and RAM. Just unscrew it and carefully pull the lids.
  • Remove the screws.
  • Remove the HDD. Slide it to the right and then pull.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Now the tricky part. We need to remove the speakers/additional control keys cover.
  • To do so, we need to lever the 3 pins in the battery bay (marked red). Do it gently not to brake them.
  • You may want to lever the marked blue pins accessible from the DVD bay, just nest to the side.
  • Now pull the cover.
  • The rest of the pins (marked yellow) will go out as you will gently pull the cover.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Remove the 3 screws marked blue now.
  • To remove the keyboard, flip it gently remembering there is the connector underneath.
  • Disconnect this connector and the keyboard is free.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • We need to unscrew 4 more screws (next to the monitor holds) to release the bottom cover.
  • Unscrew only the 2 outside screws. The middle ones hold the monitor on its place.
  • On the left side the second screw is under the bunch of cables.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Flip back, remove the cover:)
  • Finally we can see the inside of our VAIO.
  • Remove the fan - 4 screws, and detach the connector. Pull it up.
  • Now you are able to clean the area. I used some compressed air and toothbrush:)
  • That's all. Hope you liked it.
