first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • After disconnecting the Select/Start button, volume buttons, and the headphone jack, the logic board simply lifts out of the case.
  • The analog joystick comes right out with the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • With the board out, we can continue tearing into the Go.
  • A couple screws must be removed to separate the display assembly from the lower case.
  • With the lower case and logic board gone, you can see the details of the metal slider mechanism. That display ribbon cable must be designed for wear from millions of opening/closing cycles.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • We used a PSP opening tool to lift the LCD display panel out of the sliding upper case.
  • Two small speakers (with the mint green labels) stream sound from the front of the Go. They are printed with the serial number:
    • EAS1D129A VNXG9618V17a
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • The backside and the frontside of the PSP Go logic board, with joystick still attached.
  • Now we will turn our attention to identifying the many chips that make the Go... well... go.
  • The sheer number of chips and EMI covers is amazing. The device certainly has a large number of dedicated-function chips, as opposed to having a few large multi-tasking chips.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • The first picture includes:
    • Sony Computer Entertainment CXD2986A1GG
    • 9110563 20AK2L 0846
  • In the second picture:
    • SAMSUNG 922 KLSAG8DAAD-B202 flash memory provides 16GB of internal storage.
    • CIRRUS 42L52CNZ CF1S0917 low power, stereo codec with headphone and speaker amps.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 14  ¶
    • SHARP 0923 7y LR388G1 TFT-LCD controller for video out.
    • OKI L86V7657 9175902J
  • The second picture is of the QZ7-001A 95D ALPS 002433 A73457 Bluetooth communication chip.
  • For the third picture:
    • SCEI 923KMO3 4053
    • U3031 9M93
    • The small object highlighted in green on the third picture is the surface mounted microphone.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Highlighted in red on the first picture is the Fujitsu power processing module with serial number:
    • Fujitsu LTD MB44C018A 0925 M64 E1
  • Shown in the second picture, the FOXCONN T60H975 wireless chip provides 802.11b WLAN support.
  • Still no G or N support...
first image
Add Note Edit Step 16  ¶
  • And there you have it: the Go in pieces.
  • Curious how the PSP stacks up the the handheld gaming competition on the inside? We have both a DSi teardown and an iPod touch teardown.
  • Be sure to keep an eye on our teardown page for an inside look at the latest gadgets!
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
Plastic Opening Tools
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
T6 Torx Screwdriver
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ in stock
Notes Add Note Notes are offturn on
