Sony Ericsson XPERIA X1 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
Overview of the Sony Ericsson XPERIA X1 hardware with circuit diagrams and labeled chips. See www.phoneWreck.com for more detailed information on the Sony Ericsson XPERIA X1 and other devices.
first image
Add Note Edit Step 1 — Sony Ericsson XPERIA X1 Teardown  ¶
  • The Sony Ericsson XPERIA X1 is one device that’s not afraid to brag. It’s got the looks of a sophisticated modernist, an interface to temporarily boast, and the price tag that’ll blow up your mind and your surrounding minds.
  • For this phone, we had to be particularly careful when we tore it open (we love our gadgets, after all). It was relatively easy, but hidden screws are always deadly. Luckily, the shielding on the chips were easily removed.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • This device is one of the most gorgeous devices I’ve seen. Not only does it look good, it feels like a million bucks (it actually does cost a lot though). The sliding mechanism is the smoothest and most solid mechanism to date and actually tilts the screen slightly towards you. It works, and it works well. There’s absolutely no give to the device due to its brushed aluminum components. Heck, the battery door is fully aluminum, the base of the keyboard is aluminum, even the keys feel aluminum (we’re not sure they actually are though).
first image
Add Note Edit Step 3  ¶
  • Sony Ericsson/HTC has also done an amazing job on the fine details. Look at the hidden notification lights! There are accented front buttons, rubberized feet, and the curved sliding is gorgeous.
first image
Add Note Edit Step 4  ¶
  • The 4-rows of keys is definitely useful for regular typing though, and it’s even laid out with a staggering QWERTY effect that makes it easy to get used to. Unfortunately, the keys are very flush and rather soft, giving it subdued tactile feedback. Technically, this is a general complaint about slide-out keyboards, because they have to be nearly flush so that the screen can slide on top.
first image
Add Note Edit Step 5  ¶
  • And of course, the screen. The X1 sports one of the first WVGA (800×480) screens, and it’s beautiful. Colours are vibrant, small texts are clear and very visible. It’s sad that they’ve chosen to run with a resistive touchscreen rather than a capacitive, of course, they’ve given it one of the best resistive displays, with very fine film-to-screen gaps. It’s also quite responsive.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • As always, the block diagram...
first image
Add Note Edit Step 7  ¶
  • What’s interesting to note is the really smooth sliding mechanism. This is achieved through a curved backing of the screen with rollers clipped to the inside tracks.
first image
Add Note Edit Step 8  ¶
  • The actual chips being used are very similar to the ones found on the G1.
  • The main IC diagram can be found here.
  • Another interesting thing to note is the Mini-USB port. It’s actually eerily similar to HTC’s traditional ExtUSB ports. In fact, it looks just like it except that it’s symmetrical enough to only fit a Mini-USB connector inside.
  • There’s not too much to note on the front except the USB PHY, which we believe to be developed by SMSC. Again, similar chips with similar markings were found on other devices.
first image
Add Note Edit Step 9  ¶
  • On the screen, there’s actually two PCBs. One controlling the main front buttons, the optical joystick, and a logic microcontroller from Atmel, and the other that we believe houses an Epson controller for the resistive touchscreen.
first image
Add Note Edit Step 10  ¶
  • Finally, on the right, there is a connection to the front CMOS camera. Both camera modules are shown side by side, below.
  • If you have questions, comments, concerns, humorous anecdotes, be sure to let us know in the comments or through e-mail (phonewreck@gmail.com). Also be sure to visit the wiki for more pictures (http://www.phonewreck.com/wiki/index.php...)! Thanks!
Required Tools
Spudger
$2.95 · 50+ in stock
Plastic Opening Tools
54 Bit Driver Kit
$24.95 · 50+ in stock
Popular Products
iPhone 4S Replacement Battery
$29.95 · 50+ in stock
iPhone 3G Replacement Battery
$14.95 · 50+ in stock
iPhone 3G and 3GS Mute Button
$4.95 · 50+ in stock
Small Suction Cup
54 Bit Driver Kit
