Page 2 of 2
Edit Step 12 ¶
Remove these two screws to detach the sensor from the lens
The sensor has a typical 1/2.5" size. That's not a big sensor.
Here you have a 5 polish zloty coin for comparison.
5 polish zloty's is about $1.80, in case you don't grasp the size yet :)
The CCD is very shinny.
6 megapixels from a 1 / 2.5" sensor is like expecting 70 megapixels from a 35mm film camera. It's still better then pumping 12 megapixels out of a pinhead sized sensor in mobile phones.
Manufacturers, please stop the megapixel war. Thank you.
Edit Step 13 ¶
The Carl Zeiss lens from the sony camera alongside the lens from a Zorki-6 soviet compact rangefinder from 1960.
Unlike the Sony, the Zorka still works, despite being over 40 years older.
The back of the Zeiss has significantly more electronics, ribbon cables and servomechanisms than the Zorka lens
Edit Step 14 ¶
Lets get back to the body of the camera
Lift this plastic lock to remove the hight voltage chip powering the speed light.
3 cables connect this board with the lamp and they are soldered.
The capacitor has 320 micro farads of capacity and operates at 330 volts. That's 17.4 joules of potential electric energy, quite much for a speed light.
Edit Step 15 ¶
To get to the microphone and top button panel, unscrew these three.
Sony made sure that the microphone caches the sound you want, and not internal motor noise, or the sound of the wind. This is actually very impressive work, most camera manufactures don't care that much.
Finally the button panel, with the broken shutter button.
Page 2 of 2
