Sony D822-K Car Discman Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
I'm going to dissect an old friend, my first disc player. It is hoped that this teardown, while exposing the hydro-suspension and green-amber lighting, will reveal an awesomeness worthy of a Sony PS3 Slim (Gadget Lab Contest).
first image
Add Note Edit Step 1 — Sony D822-K Car Discman Teardown  ¶
  • Obtain a D822-K Discman and remote. True, it has DSP and Surround Sound, but the 90's have come and gone. It's okay to take it apart.
first image
Add Note Edit Step 2  ¶
  • Position unit so that the bottom is facing up. Remove the 6 screws.
  • Hold top and bottom of unit together as you turn the unit over, bottom facing down. Use caution; the upper and lower case, along with circuit board are now loose.
  • Watch out for the AVLS and illumination switches, they love to disappear when unsupervised. Remove top of case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Removing the CD reader: Gently pull all 3 rubber grommets sideways, away from the CD reader.
  • Slide edge of ribbon cable connector towards ribbon cable to disengage.
  • Unplug the red, white, and blue plugs from the circuit board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Observation: This is the Hydro Suspension system...really.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Remove circuit board
  • Notice the dual-color light modules. (I temporarily connected the power to show off the lights)
first image
Add Note Edit Step 6  ¶
  • Disconnect tailpiece, and power supply.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Remote: Remove the 3 screws from the bottom. Pull apart.
  • The function buttons have a neat overlay design.
first image
Add Note Edit Step 8  ¶
  • Completely disassembled. The illumination button was lost for two weeks after reassembling... but who uses amber lights anymore?
Popular Products
iPhone 3G and 3GS Power Button
$4.95 · 50+ in stock
iPod Touch Gen 2 Replacement Battery
$14.95 · 31 in stock
iPhone 3GS Replacement Battery
$19.95 · 50+ in stock
Metal Spudger Set
$7.95 · 50+ in stock
Precision Tweezers Set
$7.95 · 33 in stock
Notes Add Note Notes are offturn on
