View profile
Logout
« Previous
Page 2 of 2
Now for the other side. Carefully peel up the antenna plate so you can get at the other data ribbon.
Peel the black tape off the plug. Pry up with a screwdriver on the brown clip and remove the data ribbon.
Now for the top layer. unscrew the five screws and place them on the magnet. Pry up on the side indicated to remove the cover.
Pull out the circuit board and LCD screen assembly. Pry up on the brown clip to remove the LCD screen.
Now you can remove the data ribbon by prying up on the brown clip.
To remove the buttons, carefully pry up around the little pins and pull up.
You're done! You have taken this CD player apart and broken it down into its individual components. Now to put it back together.
Next » « Previous
$4.95 · 50+ in stock
$4.95 · 12 in stock
$2.95 · 50+ in stock
$14.95 · 50+ in stock
$24.95 · 50+ in stock
$19.95 · 50+ in stock
1024
