Sony CD Walkman D-NF430 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
I am first of all doing this to enter to win a PS3 Slim or PSP Go. I am also doing this to find out what's inside this CD player.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Sony CD Walkman D-NF430 Teardown  ¶
  • Start by looking at the fine detail of the exterior.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Open it, remove any CDs and put away. Open the battery cover and remove the battery.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Close the battery cover and locate your screwdriver.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Unscrew the six screws and place them on the magnet so you'll be able to find them later. Sony was nice enough to put the screws next to the lid at an angle so you can fit a screwdriver in there.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Insert the tip of a screwdriver between the white upper layer and the gray lower layer. Carefully pry apart. There are small clips that help hold the two layers together and you don't want to snap them.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Here's the inside of the bottom layer.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Now to remove the laser reading assembly. Carefully peel the orange data ribbon off the circuit board to the plug. Using the flat screwdriver, pry the black clip away from the tan part.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Now for the power wires. Pry up on the side opposite of the wires.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 9  ¶
  • Now for the other side. Carefully peel up the antenna plate so you can get at the other data ribbon.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10  ¶
  • Peel the black tape off the plug. Pry up with a screwdriver on the brown clip and remove the data ribbon.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • Now for the top layer. unscrew the five screws and place them on the magnet. Pry up on the side indicated to remove the cover.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Pull out the circuit board and LCD screen assembly. Pry up on the brown clip to remove the LCD screen.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Now you can remove the data ribbon by prying up on the brown clip.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 14  ¶
  • To remove the buttons, carefully pry up around the little pins and pull up.
first image
Add Note Edit Step 15  ¶
  • You're done! You have taken this CD player apart and broken it down into its individual components. Now to put it back together.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Recommended Tools
Home Tech Toolkit
$24.95 · 21 in stock
Sorting Tray
$7.95 · 15 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Products
iPhone 3G Front Panel Kit
$39.95 · 50+ in stock
iPhone 3G and 3GS Mute Button
T8 Torx Security Bit Screwdriver
$6.95 · 50+ in stock
Magnetizer/Demagnetizer
Heat Gun
$24.95 · 8 in stock
