This teardown is not a repair guide. To repair your Sony Walkman WM-4, use our service manual.
  1. Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: step 1, image 1 of 2 Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: step 1, image 2 of 2
    • Flip the Sony Walkman so that its rear side faces you.
    • Use a screwdriver to remove the two screws from the surface of the Walkman.
    • Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
    • Remove the batteries from the Walkman.
  2. Sony Walkman WM-4 Teardown: step 2, image 1 of 2 Sony Walkman WM-4 Teardown: step 2, image 2 of 2
    • Turn over your Walkman and gently press the cover to open the cassette holder.
    • When the cassette holder is opened, you can see two more screws.
    • Using a screwdriver, remove the two screws.
  3. Sony Walkman WM-4 Teardown: step 3, image 1 of 2 Sony Walkman WM-4 Teardown: step 3, image 2 of 2
    • Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman.
    • Be careful so you dont break the tabs!
    • Once the Walkman is opened, you can troubleshoot for any issues, remove the old wires and attach new ones, or even reassemble the Walkman.
lenzo
125 Reputation
1 Guide authored
One Comment
Drive belt trashed any ideas where to get one?
nz-tiger - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 40
All Time: 15,926
