Sony Ericsson Xperia X10 Mini E10i Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
In the midst of the iPhone 4 craze, we became impatient and decided we needed to tear down a phone, you know, just to keep us in tip-top shape. And lo-and-behold, the Sony Ericsson Xperia X10 Mini E10i.
A big thanks to Brian at EDN for providing the phone for this teardown. Be sure to check out his Xperia X10 Mini Preview!
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Sony Ericsson Xperia X10 Mini E10i Teardown  ¶
  • The Sony Ericsson Xperia X10 Mini E10i is the smaller version of the Sony Ericsson Xperia X10.
  • Tech Specs:
    • 600 MHz Qualcomm MSM7227
    • 256 MB RAM and 256 MB internal ROM (only 128 MB accessible)
    • 2.6" color transflective TFT display with a resolution of 240 X 320 pixels.
    • 5 Megapixel camera with autofocus
    • 802.11 b/g Wireless + Bluetooth 2.1
  • The backside of the X10 Mini E10i is characterized by a smooth plastic rear case with openings for the camera, LED flash, and speaker.
Add Note Edit Step 2  ¶
  • The controls of the X10 Mini E10i are pretty standard.
    • The bottom of the X10 Mini E10i integrates a 3.5 mm headphone jack as well as a micro-USB port.
    • The top edge houses the power button.
    • The left side accommodates the volume and camera buttons, leaving the right side blank and featureless.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • The 5.0 megapixel camera in the X10 Mini E10i features a 1X optical zoom with autofocus and a built-in LED flash.
  • The camera itself measures in at 8.8 x 9.1 x 6 mm.
Add Note Edit Step 4  ¶
  • A few quick pries with an iPod opening tool around the perimeter of the X10 Mini E10i and the rear case easily pops off to access the phone's innards.
  • The actual electronic volume and camera buttons are attached directly to the logic board. The buttons you press on the outer case are just chrome covers.
Image #1
Add Note Edit Step 5  ¶
  • A thumbnail is all that is needed to remove the microSD card from its housing in the inner case.
  • The simple design of the Mini E10 allows most components to plug directly into the logic board. The only exception is the external microSD card slot.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • A single T5 Torx screw and a few plastic clips are all that secure the antenna assembly to the inner case.
  • The antenna assembly uses simple yet effective pressure contacts to make a connection with the logic board. No connectors necessary!
Add Note Edit Step 7  ¶
  • A couple more T5 Torx screws secure the rear inner case and logic board to the rest of the X10 Mini E10i.
  • Disconnect the battery connector from the logic board with the flat end of a spudger.
  • Pry up the SIM card socket connector and remove the rear inner case from the the logic board.
Image #1
Add Note Edit Step 8  ¶
  • The 3.7V 950 mAh Li-Polymer battery allows for 4 hours of talk time.
  • Measuring 40 x 35 x 5.5 mm and weighing in at a scant 18 grams, the X10 Mini E10i's battery provides up to 360 hours of 3G standby time.
    • The batteries of both the iPhone 3GS and the X10 Mini E10i have capacities of about 53 mAh per gram.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 25 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Products
iPad 2 Front Panel Assembly
$134.95 · 50+ In stock
iPhone 4S Replacement Battery
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ In stock
