Sky TV Remote Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
Teardown of the Sky TV Remote, note: not Sky+ or Sky HD.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Sky TV Remote Teardown  ¶
  • This is it. Well, this is it in a functional state.
  • Remove the batteries before starting!
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Use a Philips head screwdriver to remove this screw
  • Use a spudger to unlock all the tabs around the sides, start at the bottom
  • Work your way all the way around the remote, this is flippin' tricky.
  • Brute force is compulsory.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • After all the tabs are off, the body should just fall away leaving the buttons, the circuit board, the case and the black infra-red bit at the end.
  • Ta-daa!
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #1 Screwdriver
$8.95 · 14 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
PC2-5300 2 GB RAM Chip
$49.95 · 50+ in stock
iPhone 3G Replacement Battery
$14.95 · 50+ in stock
Heavy-duty Spudger
$4.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 50 in stock
Notes Add Note Notes are offturn on
