Alright. This guide is a teardown to show the safest and easiest way to take apart your genesis.
This teardown is not a repair guide. To repair your Sega Genesis II, use our service manual.
Carefully lift the top off of the console.
It should come off relatively easy
If it doesn't, ensure that all four screws are removed
Remove the six, gold, 8mm screws and the three, black, 8mm screws holding down the EM shield
After removing the screws, the shield will come off very easily.
Remove the two 17mm black screws on the left and right side of the PIN to release the circuit board from the bottom EM shield.
After the screws are releases, the circuit board can easily be removed from the console.
Embed this guide
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Preview
