This teardown is not a repair guide. To repair your Sega Genesis II, use our service manual.
  1. Sega Genesis II Teardown, Sega Genesis II Teardown: step 1, image 1 of 1
    • Flip the system over
  2. Sega Genesis II Teardown, Removing the Screws: step 2, image 1 of 2 Sega Genesis II Teardown, Removing the Screws: step 2, image 2 of 2
    • Remove the four outer screws (you may want a small cup to keep your screws in.)
  3. Sega Genesis II Teardown: step 3, image 1 of 1
    • Take plastic top off.
  4. Sega Genesis II Teardown, Removing the Screws: step 4, image 1 of 1
    • Remove the nine inner screws.
  5. Sega Genesis II Teardown: step 5, image 1 of 1
    • Remove metal piece.
  6. Sega Genesis II Teardown: step 6, image 1 of 1
    • You now have access to your circuit board. (If you wish to remove the circuit board, continue.)
  7. Sega Genesis II Teardown: step 7, image 1 of 1
    • Remove the two screws highlighted in picture to remove the circuit board.
  8. Sega Genesis II Teardown: step 8, image 1 of 1
    • Lift the black piece of plactic up.
  9. Sega Genesis II Teardown: step 9, image 1 of 1
    • Lift up the metal piece.
  10. Sega Genesis II Teardown: step 10, image 1 of 1
    • You now have access to the inside of the bottom plastic piece.
  11. Sega Genesis II Teardown, Circuit Board: step 11, image 1 of 3 Sega Genesis II Teardown, Circuit Board: step 11, image 2 of 3 Sega Genesis II Teardown, Circuit Board: step 11, image 3 of 3
    • This is the circuit board.
  12. Sega Genesis II Teardown, Reassemble: step 12, image 1 of 1
    • Do the steps backwards to reassemble.
Thor Odinson
152 Reputation
1 Guide authored
One Comment
Good job. Thanks
luca - Reply
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 172
All Time: 11,114
