This teardown is not a repair guide. To repair your Scanmaker Air, use our service manual.
  1. Scanmaker Air Teardown, Prying open: step 1, image 1 of 1
    • I used flat 2 out of the IFixIt kit I have. Slide it from USB down on both sides of device. Likely could be done better with other tools
  2. Scanmaker Air Teardown, Internal clips: step 2, image 1 of 1
    • Mindful of these. I'm not sure at writting how delicate they are
  3. Scanmaker Air Teardown, Inside look: step 3, image 1 of 1
    • Left is "front". Right is "back"
  4. Scanmaker Air Teardown, Replacing + putting together: step 4, image 1 of 1
    • I was mostly straight up and down with a slight angle to wiggle the USB port down. Bottom of plastic housing to battery side. I placed the orange tip after. Then snap housing back on. Feel is different but may still work (I tore down 2 that are unknown cause of failures). Make sure orange part is in before placing housing back on
Bookworm 3616
134 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 129
