Samsung Omnia i910 Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
Overview of the Samsung Omnia hardware with circuit diagrams and labeled chips. See www.phoneWreck.com for more detailed information on the Samsung Omnia and other devices.
first image
Add Note Edit Step 1 — Samsung Omnia i910 Teardown  ¶
  • The Samsung Omnia is not a “new” device – we had one lying around and all the hype surrounding the fresh Omnia HD had us thinking we might as well break it open to see what makes it hum. The verdict? You’ll have to read on. Simply said however, this device was built for function.
  • At a time when everybody and their brother/sister seems to be creating an iPhone clone, the Samsung Omnia came out as a fully featured device to meet the requirements and fill the voids that exist in Apples highly acclaimed platform. Man, is this thing packed with features… Let’s see how it stacks up from a design perspective.
first image
Add Note Edit Step 2  ¶
  • The Samsung Omnia is a well built device but it’s no Xperia. Unlike most of the BlackBerry devices we’ve seen the chrome feature around frame of the device is actually metal – not painted plastic that scuffs and scrapes with everyday use.
  • The battery cover and trim pieces that make up the surroundings fit within small tolerances, and there is very little give or “flexible” feeling as you use the device.
  • The screen is resistive but doesn’t feel loose like some of the other devices we’ve seen with the same technology.
first image
Add Note Edit Step 3  ¶
  • You’ll notice the device contains a pretty small and pretty packed PCB.
first image
Add Note Edit Step 4  ¶
  • Unfortunately the TouchWiz UI didn’t really tickle our fancy. The 3.2”, 240×400 screen simply isn’t big enough for all of the necessary widgets and you’ll often find yourself accidently moving the icons around the screen. Moreover, the screen seems fairly small for the overall size of the device. From an aesthetics perspective, it’s a little too tall and narrow. We found ourselves often wishing for a little bit more real-estate during typing related activities.
first image
Add Note Edit Step 5  ¶
  • What’s with the proprietary headphone/USB/Tv-out jack? It’s really cool that all of these functions are provided via a single jack, but sometimes you don’t have the specific Samsung cable handy. It’s also annoying to plug your 2.5mm headphones into an included adapter. 2.5mm? ??!!! This is like the BlackBerry of 2002!
first image
Add Note Edit Step 6  ¶
  • This device is well built. As such, it was a little bit tricky to take apart. Thankfully, all shielding was clip in and the device’s brains were easily revealed. Muahahahaha.
first image
Add Note Edit Step 7  ¶
  • The primary IC diagram can be found here.
  • Notably, this device runs on the Qualcomm 6800A and Marvell PXA312. These devices are connected via a Cypress Dual-Port bridge and have separate Power Management Devices. Note that this PCB is impressively packed and impressively small! Another thing to point out is the presence of an SMSC USB PHY. We’ve seen these devices on a variety phones we’ve ripped apart.
  • Bluetooth goes to CSR and Wi-Fi to Marvell. The GPS win goes to Avago. Note the massive quintplexer!
first image
Add Note Edit Step 8  ¶
  • The one thing we knew the phone had but couldn’t find was the 8GB internal memory. Where could it be? We eventually found it hiding underneath the shield covering the processor side of the PCB - very sneaky!
Popular Products
iPod Touch Gen 2 Replacement Battery
$14.95 · 31 in stock
Spudger
$2.95 · 50+ in stock
Pro Tech Toolkit Expansion 1
$79.95 · 48 in stock
Mac Mini Logic Board Removal Tool
$14.95 · 50+ in stock
Notes Add Note Notes are offturn on
